How much to replace 12 metres of guttering....
Started by chrisgixer, 30 April 2014, 22:22:28
chrisgixer
...and facia boards, with
Well here's the list.
Quote for new UPVc system
1. To remove old rotten wooden fascia, soffit boards and gutters from front of property
2. Supply and fit new white UPVc soffits, fascia boards and cladding above windows
3. To supply and fit new plastic felt support trays to eve ends
4. To move Ariel and refix to brick if still needed, if not remove it completely
5. To paint in white gloss peace of timber above window as discussed
6. To fit new guttering linking into downpipes on both sides
Remove all rubbish from property leaving clean and tidy as found All work is fully guaranteed for 10 years
chrisgixer
chrisgixer
It's probably less than £50 in materials.
Quote from: chrisgixer on 30 April 2014, 22:29:50
Wow, prices of FSB materials must have gone down a lot since I was buying them 10 years ago! If only other prices had done the same.
kevinp58
Guttering will be around that facia and soffit will be £100 then then cladding and fixings how much is there?
chrisgixer
Cladding is just a PVC sheet about 1ft by 6ft above two windows.
kevinp58
Quote from: chrisgixer on 30 April 2014, 22:57:33
Another £20 should cover that then, so around £500-£550 should be a fair estimate.  :y but I suspect it will be well over the grand.  ::)
chrisgixer
Here's the offending article
It's the section between the two drain pipes, above the two windows and the porch.
kevinp58
Quote from: chrisgixer on 30 April 2014, 23:04:44
Sharp intake of breath and a tut  ::) that'll need scaffolding.  ::) ::) that's what they will say.  :y
chrisgixer
Yep, then they'll scamper up there on a ladder and bounce it across as required.
Oh yes, scaffolding needed.. I stand by my original number..
BTW my next door neighbour does roofing/guttering/etc/etc if you want a second quote
chrisgixer
Yes first quote was 1200.
Down to £890 so far.
The PVC-U cost bugger all, bought a stack of it to do the MIL's large double garage and front and had change from 200 notes.
Guttering costs very little.
Gaffers
Quote from: Marks DTM Calib on 01 May 2014, 10:17:45
Yes, it's always the taking of the wee wee which forms the most expensive part of these quotes.  Often comes under the heading of labour or miscellaneous
