Author Topic: orsan nightbreakers  (Read 3246 times)
mickyboy123
  • brighton
  • hi
    • 2.2 cd omega.petrol auto
orsan nightbreakers
« on: 03 May 2014, 08:27:48 »
hi guys,
i fancy some brighter bulbs but there are so many would be glad of some help as to weather these will fit okay or a link to some orsan nightbreakers that definately will. here are the specs of the one i have seen.
type. orsan nitebreaker plus.
fitment. h7-477/499.
12v.
55w.
part no.64210nbp.
 8)
zeon.
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
Re: orsan nightbreakers
« Reply #1 on: 03 May 2014, 08:35:07 »
I was also thinking about fitting some of those. They look good. Be interesting what the other members say about them.
mickyboy123
  • brighton
  • hi
« Reply #2 on: 03 May 2014, 08:39:55 »
they do look great. but there so many its confusing well it is for me any way. i just want to be sure they will fit before i order. nothing worse than ge :'(tining the wrong part is there.
Andy A
  • Bristol UK
« Reply #3 on: 03 May 2014, 08:50:09 »
What year is your Omega?
mickyboy123
  • brighton
  • hi
« Reply #4 on: 03 May 2014, 09:06:45 »
its 2.2 cd. year 02 plate.
  • Auckland
    • Mazda MPV
« Reply #5 on: 03 May 2014, 09:24:38 »
Index here to Common Omega Issues & FAQ
& list of bulbs (lamps) here Omega Light Bulb List
Osram & Philips were both OE fitment and you can't go wrong with them. If it says "orsan" on the lamps you are looking at then I would assume they were a knock off copy. :-\
grain.ben
« Reply #6 on: 03 May 2014, 16:00:39 »
I have them on mine, and they do make a 'noticeable' improvement over standard bulbs. Life expectancy varys although mine have been in 2 years (touch wood)  :)
grain.ben
« Reply #7 on: 03 May 2014, 16:03:07 »
Just noticed that, make sure they are OSRAM
« Reply #8 on: 03 May 2014, 21:11:57 »
Got Osram Nightbreaker+ ones in my 2.2, big improvement over the old stock ones.
Popped them in a few years back, one blew last year a cheapo-halfrauds one went in, bloody awful!
So pair of the nightbreakers back, in loads better  :)
« Reply #9 on: 04 May 2014, 11:22:01 »
I use the Phillips equivalent in the Battlebus, improvement over stock.
Apart from one, all my Omegas have had factory HIDs
paulg
  • Spalding
    • 04 3.2 manual MV6
« Reply #10 on: 06 May 2014, 03:41:07 »
Bought some last month, a lot better than most!  :y
slowboy
  • lode
« Reply #11 on: 06 May 2014, 16:18:56 »
 :y :y
mickyboy123
  • brighton
  • hi
« Reply #12 on: 06 May 2014, 16:24:20 »
okay thanks guy for all your advice ,got some on :y the way ,will let you no if im impresed . :y
iliak
  • Moscow Russia
    • Opel Omega B, X25XE
Re: osram nightbreakers
« Reply #13 on: 07 May 2014, 16:30:10 »
as an alternative you may try Philips X-treme Power, p/n 12258XVS2.
« Last Edit: 07 May 2014, 16:33:33 by iliak »
