Author Topic: 2.2 petrol estate misfire  (Read 1865 times)
dukie
  • kent
    • omega 2.2cdx Est
« on: 03 May 2014, 23:33:30 »
Help!  2.2 auto petrol has misfire on cylinder 4,runs like sack of s**t! yet if revved to above 2000rpm runs ok,back to idle and misfires badly. Cleared codes which keep coming back as 1781 & 1740. New plugs fitted,coli pack tested and throttle housing cleaned but still no joy! any ideas?????
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
Re: 2.2 petrol estate misfire
« Reply #1 on: 04 May 2014, 08:06:59 »
Might be wrong, but I believe it's your can sensor failing.
Lift youre bonnet and the sensor is at the FRONT top part of engine,,underneath black plastic cover saying ecotec on....the wire to it is going in where the cut out on cover is.   about 10 minutes to change it
They'll be an expert on shortly to confirm or deny ::)
HTH's :y
AKA - Mr Bracket
steve6367
« Reply #2 on: 04 May 2014, 08:23:38 »
When the coil pack was out any oil or water in the plug wells?
Steve
badmuver
dukie
  • kent
    • omega 2.2cdx Est
Re: 2.2 petrol estate misfire (2001 cdx auto)
« Reply #4 on: 10 May 2014, 15:01:19 »
Replaced camshaft sensor,engine started and ran very lumpy and now will not start again,turns over but does not fire,checked key and re synched it to car just in case but eml light not flashing so don't think its that...any ideas or is this a trip to scrapyard for car that's only done 66,000 miles!??? >:(
« Reply #5 on: 10 May 2014, 15:04:35 »
2.2 is good for decent miles, mine is on 171k  :y
Unplug the cam sensor, then start, it will take a lot of cranking, but should fire and idle ok. Assuming everything else is fine.
Another test, unplug the MAF sensor, see how it runs.
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
« Reply #6 on: 10 May 2014, 20:14:50 »
I had misfire probs on mine recently. Turned out it was one coil pack rubbers were past it split on bottom. New set fitted £18 from Vauxhall problem solved :y
dukie
  • kent
    • omega 2.2cdx Est
« Reply #7 on: 11 May 2014, 23:00:27 »
Put the new rubbers on coil pack first so I know its not that,just keeps turning over but making no attempt to start. Got spark at plugs so ruled out coil pack,throttle body and Maf all cleaned out,new cam sensor fitted !!!! any suggestions gratefully received  :-[ :o
« Reply #8 on: 11 May 2014, 23:59:51 »
Where did you buy the camshaft sensor?
Genuine Vauxhall from a genuine dealer only :y none of that ebay/pattern rubbish ::)
« Reply #9 on: 12 May 2014, 13:33:52 »
Let it stand overnight. Start from cold and watch the exhaust. Any steam? Any funny smells eg petrol in the coolant bottle?
dukie
  • kent
    • omega 2.2cdx Est
« Reply #10 on: 12 May 2014, 23:39:51 »
Yeh it was an Genuine sensor...did run misfiring in limp mode before changing,now just turns over but will not fire...think gallon of petrol and a match is next option!!!! >:( :( >:( :(
