Author Topic: Rear spring idents  (Read 2949 times)
chrisgixer
Rear spring idents
« on: 04 May 2014, 10:54:00 »
Anyone got any info on rear spring idents? And fronts if possible.
Re: Rear spring idents
« Reply #1 on: 04 May 2014, 11:04:45 »
Only whats on EPC
chrisgixer
« Reply #2 on: 04 May 2014, 11:06:00 »
Only whats on EPC
Which I no longer have access to. So if you fancy a quick copy and paste? :)
« Reply #3 on: 04 May 2014, 11:13:53 »
Only whats on EPC
Speaketh booolllax I believe, or have you broken it?
chrisgixer
« Reply #5 on: 04 May 2014, 12:03:49 »
this any good ? http://www.partsbase.org/opel/omega-b-1994-2003-13-8-1-1-rear-springs-saloon-25-26-27-f69-m69-p69-except-police-vehicle/
Thanks Serek, but unless I'm being thick, it doesn't describe what each ident is? I have some springs in the garage with numbers but no listing for their specific use.
I believe LA are self levelling, although mine where LA and rode too high.
And LW might be lsc. But I have nothing to confirm. Part numbers are a bit tricky too.
« Reply #6 on: 04 May 2014, 12:24:53 »
LU saloon without removable towbar
LW saloon with removable towbar
LR estate with removable towbar
LX estate without removable towbar
« Last Edit: 04 May 2014, 12:33:06 by RobG »
« Reply #7 on: 04 May 2014, 12:46:32 »
Saloon, non Plod:
  1X 90487519 4 24 002 SPRING, ASSY., REAR, IDENT LG (SET) (EXC.ARMOURED BODY) (EXC.BAD ROAD PACKAGE) 20SE, X20SE, X20XEV (C)  -V1999999 1
    Note: EXCEPT AUTOMATIC SELF LEVELLING DEVICE
    2X 90487520 4 24 003 SPRING, ASSY., REAR, IDENT LH (SET) (EXC.ARMOURED BODY) (EXC.BAD ROAD PACKAGE) X30XE SALOON 27, P69 (C)  -V1999999 1
    3X 90542359 4 24 020 SPRING, ASSY., REAR, IDENT LP (SET) (EXC.ARMOURED BODY) (EXC.BAD ROAD PACKAGE) EXC.SPORT (C) W1000001-  1
    4X 90542779 4 24 392 SPRING, ASSY., REAR, IDENT LS (SET) (EXC.ARMOURED BODY) (FOR BAD ROAD PACKAGE) EXC.SPORT   1
    5X 90271117 4 24 323 SPRING, ASSY., REAR (SET) (EXC.ARMOURED BODY) 20SE, X20SE, X20XEV (C)  -V1999999 1
 Note: USED WITH AUTOMATIC SELF LEVELLING DEVICE
    6X 90295669 4 24 339 SPRING, ASSY., REAR, IDENT LC (SET) (EXC.ARMOURED BODY) X25XE, U25TD, X25TD (C)  -V1999999 1
    7X 90295666 4 24 341 SPRING, ASSY., REAR (SET) (EXC.ARMOURED BODY)  (C) W1081185-  1
    8X 90397132 4 24 361 SPRING, ASSY., REAR (SET) (FOR ARMOURED BODY)    1
    9X 9193196 4 24 050 SPRING, ASSY., REAR, IDENT LU (SET) (NOT USED WITH REMOVABLE TOWING ATTACHMENT) SPORT (C) Y1000001-  1
    10X 9193197 4 24 051 SPRING, ASSY., REAR, IDENT LW (SET) (USED WITH REMOVABLE TOWING ATTACHMENT) SPORT (C) Y1000001-  1
« Reply #8 on: 04 May 2014, 12:47:14 »
Saloon, Plod:
  11X 90271116 4 24 322 SPRING, ASSY., REAR, IDENT DY (SET)  (C)  -V1999999 1
    3X 90542359 4 24 020 SPRING, ASSY., REAR, IDENT LP (SET) EXC.SPORT (C) W1000001-  1
« Reply #9 on: 04 May 2014, 12:48:54 »
Estate:
  12X 90487521 4 24 000 SPRING, ASSY., REAR, IDENT LJ (SET) (EXC.AMBULANCE/HEARSE) (EXC.BAD ROAD PACKAGE)  (C)  -V1999999 1
    13X 90542360 4 24 021 SPRING, ASSY., REAR, IDENT LQ (SET) (EXC.AMBULANCE/HEARSE) (EXC.BAD ROAD PACKAGE) EXC.SPORT (C) W1000001-  1
    14X 90542780 4 24 393 SPRING, ASSY., REAR, IDENT LT (SET) (EXC.AMBULANCE/HEARSE) (FOR BAD ROAD PACKAGE) EXC.SPORT   1
    15X 90486670 4 24 379 SPRING, ASSY., REAR, IDENT KY (SET) (FOR AMBULANCE)  (C)  -X1999999 1
   View part history 16X (90487522) (4 24 001) SPRING, ASSY., REAR, IDENT LK (SET) (NLS.- NO REPLACEMENT PART)  (C)  -V1999999 1
    17X 90542361 4 24 022 SPRING, ASSY., REAR, IDENT LR (SET) (USED WITH AUTOMATIC SELF LEVELLING DEVICE)  (C) W1000001-  1
    18X 9193198 4 24 052 SPRING, ASSY., REAR, IDENT LX (SET) (USED WITH LOWERED SPORTS CHASSIS) (NOT USED WITH REMOVABLE TOWING ATTACHMENT)  (C) Y1000001-  1
    17X 90542361 4 24 022 SPRING, ASSY., REAR, IDENT LR (SET) (USED WITH LOWERED SPORTS CHASSIS) (USED WITH REMOVABLE TOWING ATTACHMENT)  (C) Y1000001-  1
   View part history 19X (90349884) (4 24 317) SPRING, ASSY., REAR (SET) (FOR HEARSE) (NLS.- NO REPLACEMENT PART)    1
chrisgixer
« Reply #10 on: 04 May 2014, 13:04:41 »
Nice one. Ta
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« Reply #11 on: 04 May 2014, 13:18:00 »
I have LU printed on the rear springs of my 04-plate MV6 if that's of help, p/n 9193196. Looking at TB's list, I'm guessing 'Sport' refers to MV6?
PM with your requests.
  • Auckland
    • Mazda MPV
« Reply #12 on: 04 May 2014, 13:59:41 »
That was my experience too  :(
« Reply #13 on: 04 May 2014, 14:10:00 »
Could this be down to lazy dealers/blind repairers buying/fitting whatever was cheapest to fix a car without really considering the implications two or three owners down the line :-\
