Author Topic: Spanner light  (Read 3287 times)
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
Spanner light
« on: 05 May 2014, 13:12:58 »
Hi all,
After having made a first attempt at changing an oil cooler yesterday, I refilled the cooling system with water and cleaner and refilled the oil.
Car started after a few attempts and ticks over fine.
Unfortunately I now have a spanner light lit up??
Using my Sealey code reader, it's says there are no codes, but if I select clear codes, the light goes out, but then a few seconds later, comes back on ???
Any suggestions as to what maybe causing this please?
TIA :y
AKA - Mr Bracket
martin42
Re: Spanner light
« Reply #1 on: 05 May 2014, 14:03:49 »
Double check all electrical connections,dual ram at rear of plenum can be easily missed  :y
blackviper90210
Re: Spanner light
« Reply #2 on: 05 May 2014, 14:17:13 »
Is that the large plug right at the back? If so, I did connect it, but I'll go and check it's still is  :y
AKA - Mr Bracket
Re: Spanner light
« Reply #3 on: 05 May 2014, 14:20:06 »
And maf connection ..
blackviper90210
Re: Spanner light
« Reply #4 on: 05 May 2014, 15:13:27 »
Thanks for the replies. As soon as SWMBO returns and takes the kids off me! I'll go and have a look :y
AKA - Mr Bracket
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Spanner light
« Reply #5 on: 05 May 2014, 15:20:25 »
Does the code come up with a peddle trick?
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Spanner light
« Reply #6 on: 05 May 2014, 16:49:02 »
Really need the code mate via pedal/paperclip test but I wouldn't be too concerned.... the code will more than likely relate to something you forgot to re-connect bearing in mind you just did quite a big job with it.
TPS is the one I always forget to reconnect  ::) ;D
RIP Paul Lovejoy
blackviper90210
Re: Spanner light
« Reply #7 on: 05 May 2014, 19:56:12 »
Never thought to do a paper clip test :-[
I'll do that at work tomorrow. Ref TPS, what is that?
cheers,
Dave
AKA - Mr Bracket
the alarming man
  • medway kent
    • disco V8
Re: Spanner light
« Reply #8 on: 05 May 2014, 20:27:22 »
throttle position sensor
martin42
Re: Spanner light
« Reply #9 on: 05 May 2014, 20:45:50 »
Pedal trick not paper clip test  :y
