Author Topic: Worrying noise  (Read 1973 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Worrying noise
« on: 06 May 2014, 11:18:15 »
2.5TD Auto Estate, 118k, owned and maintained for 15 years. At 76mph or so I now get a nuisance low pitched boom/whine, apparently from the rear of the vehicle, possibly driver's side. Same in 3rd or 4th gear, applying handbrake seems to have no effect on noise. Any suggestions. :-\ :-\ :-\
Re: Worrying noise
« Reply #1 on: 06 May 2014, 11:23:29 »
Brave putting handbrake on at 76mph  ;D
Could be a wheel bearing, no noise at lower speeds, high speed only?  :-\
Shackeng
  • Ramsbury
Re: Worrying noise
« Reply #2 on: 06 May 2014, 11:33:31 »
Handbrake on often helps to identify if it is a wheel bearing as the noise can change.
The noise is only really apparent at about 76 and above, although there is also a suggestion of it as it passes through 50. :-\ :-\ :-\
mickyboy123
  • brighton
  • hi
    • 2.2 cd omega.petrol auto
Re: Worrying noise
« Reply #3 on: 06 May 2014, 11:42:24 »
try this, get to about 30 or 40 mph then take your foot of the gas, if the noise pauses for a split second and then start agen it will be your bearings in the back axle , i have had this in a vauxhall carlton and its a horible noise like a high piched whine.
Shackeng
  • Ramsbury
Re: Worrying noise
« Reply #4 on: 06 May 2014, 12:22:08 »
Thanks for the suggestion, but unfortunately there is no discernible noise at 30-40! (See OP)
Re: Worrying noise
« Reply #5 on: 06 May 2014, 13:00:52 »
Might be worth checking for an exhaust blow at the rear. Mine sounded just like a rumbling bearing when it leaked in front of the back box.
Also, check both rear tyres for anything untoward - strange wear pattern or any bulges, for example. failing that, it could be a wheel bearing, lobro joint or the diff, but very unlikely at that mileage, I'd say - unless a driveshaft gaitor has perished and let the joint deteriorate.
Re: Worrying noise
« Reply #6 on: 06 May 2014, 13:01:13 »
Swap the tyres over and see if the nosie moves.
Shackeng
  • Ramsbury
Re: Worrying noise
« Reply #7 on: 06 May 2014, 14:34:55 »
Thanks guys, I'll check these out, exhaust sounds promising as tyres are almost new Enduros. :y :y :y
slowboy
  • lode
Re: Worrying noise
« Reply #8 on: 06 May 2014, 16:12:25 »
my rear drivers side wheel bearing started like that. it got worse over two years so got sereck to change it .ok now.
Page created in 0.108 seconds with 17 queries.
