Author Topic: Polen Filter  (Read 1370 times)
wesagog
Polen Filter
« on: 06 May 2014, 18:04:31 »
Hi,
If anybody can help me how to remove the polen filter to clean it, with pictures please...
Thanks in advance
Re: Polen Filter
« Reply #1 on: 06 May 2014, 18:09:08 »
http://www.omegaowners.com/forum/index.php?topic=90535.0
This guide is really for accessing the scuttle drain that lives at the bottom of the pollen filter housing. I'd just replace the filter ....... once wet, they're generally only worth replacing.
wesagog
Re: Polen Filter
« Reply #2 on: 06 May 2014, 18:14:00 »
I can't see the polen filter in the guid  :(
Re: Polen Filter
« Reply #3 on: 06 May 2014, 18:15:44 »
Just open the scuttle drain flap, as per above. You will see it clear as day  :y
Re: Polen Filter
« Reply #4 on: 06 May 2014, 18:24:13 »
If you go to the car  ::)  ::) .......... you'll see it if you try to clear the drain as above.  :y  :y
wesagog
Re: Polen Filter
« Reply #5 on: 06 May 2014, 18:58:57 »
Thank You Dears :y
