Pages: [1] 2 3  All   Go Down
Author Topic: Took my daewoo up Sutton Bank on Monday  (Read 3369 times)
Stemo
« on: 07 May 2014, 10:56:12 »
Those GM 1.8 units have got no bottom end torque at all. It's a 25% gradient and my old, 1.6, Zafira would go up most of it quite happily in 3rd, but not the orlando. Rev the nuts out of it in 2nd, change up and..........nothing. ;D Down to second and stay in second.
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: Took my daewoo up Sutton Bank on Monday
« Reply #1 on: 07 May 2014, 10:59:37 »
Either that or the Pedal/seat/steering wheel interface has increased in mass ::)
Stemo
« Reply #2 on: 07 May 2014, 11:04:29 »
Listen, fatty, I'm 12.5 stone and have been since I was a yoof. ;D
The passenger seat occupant may have increased slightly in mass, I suppose. ::)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #3 on: 07 May 2014, 11:20:34 »
What  :o
Each buttock  ;D ;D
« Reply #4 on: 07 May 2014, 11:23:42 »
No each teste!  ;D
Stemo
« Reply #5 on: 07 May 2014, 11:28:16 »
Rog
« Reply #6 on: 07 May 2014, 11:30:57 »
Took Pushed my daewoo up Sutton Bank on Monday
Corrected for you  ;)
Gaffers
« Reply #7 on: 07 May 2014, 11:40:17 »
No each teste!  ;D
More like each chin!
« Reply #8 on: 07 May 2014, 11:44:19 »
Orlando is a bit on the porky side too, compared to Zafira?
« Reply #9 on: 07 May 2014, 12:50:24 »
Given the two engines are basicaly the same (with the 1.8 being a higher cc version but same block, head design etc, VVT, yada yada yada) it should be the same or better.....unless they screwed the gearing up and got the gap between second and third a bit long
« Reply #10 on: 07 May 2014, 13:08:50 »
That's a 1 in 4 hill, the same as Porlock hill.......which means it's fooking steep. :y
It's little wonder that your 'arthritic' Daewoo had trouble. :)
My MV6 would have romped up . :y
scimmy_man
  • yorkshire
« Reply #11 on: 07 May 2014, 13:14:01 »
I often see cars stuck on it,
the best one was 4 LARGE ladies pushing a micra up one was steering through the window, ;D
Stemo
« Reply #12 on: 07 May 2014, 13:20:04 »
I'm not sure about the gear ratios but, as Tunnie says, the orlando 'feels' heavier. On the motorway, in 5th, it takes a while to get from 60 to 80.
Stemo
« Reply #13 on: 07 May 2014, 13:22:41 »
What? All the way up? Without breaking down? Don't think so.  ;D
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #14 on: 07 May 2014, 13:29:52 »
Next time you are up there take your car up Rosedale Chimney. That is even steeper. I watched a bay Austin rally once there. They all made it!.
Pages: [1] 2 3  All   Go Up
