Author Topic: Tartarini lpg system  (Read 4657 times)
martin42
« on: 07 May 2014, 20:38:31 »
According to some info in the paper work for the frontera this is the lpg system installed,as previous owner was a bright spark,he has mislaid the certificate.
First question how can i get replacement,if not how do i go about getting 1
2nd question is ive driven it on lpg for 60 miles,the leds havnt gone down on gauge for useage,,stuck 20 ltrs in tonight and still the same,is that normal  ;D
Re: Tartarini lpg system
« Reply #1 on: 07 May 2014, 21:27:29 »
There are no certificates now. Check LPG register online.  :y
martin42
« Reply #2 on: 07 May 2014, 21:38:36 »
I have checked but not showing on there  :(
« Reply #3 on: 07 May 2014, 22:24:10 »
Was it DIY job? Either way if no paper certificate, needs to be re-certified and put on the register
« Reply #4 on: 08 May 2014, 19:38:08 »
Ask him where it was certified, then call them. They may be willing to shove on register, if they still have details on file.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #5 on: 08 May 2014, 20:04:17 »
Ive had that before, where its been parked up for a while with no battery, guessing the ECU needs reprogramming for the correct Contents Sender / Display.
martin42
« Reply #6 on: 08 May 2014, 22:18:12 »
Its got a stag ecu,how do i reset it. :y
omega squared
  • london area
    • 335i/race car/2 x V6 est
« Reply #7 on: 09 May 2014, 01:18:40 »
If you have the Stag ECU you will need to pull on the left antler for 5 seconds (with the ignition on) ... then read the codes.
nothing tows better than an Omega estate in this price range
« Reply #8 on: 09 May 2014, 08:26:15 »
Why do you want to reset it?
« Reply #9 on: 09 May 2014, 09:44:16 »
I wouldn't do anything to reset it, esp given the Stags are a bit of a pain to calibrate.
How is the electronic gauge comparing with the mechanical gauge on the tank?
« Reply #10 on: 09 May 2014, 09:47:57 »
Thing is, the gauge calibration is stored in the same memory as the LPG mapping, so if that really has gone bad I'd expect it to be running like a bag of spanners on gas. More likely to be a problem with the gauge sensor or wiring, IMHO.
« Reply #11 on: 09 May 2014, 15:39:08 »
Surely if it has a Stag ecu it's a Stag system :-\ or have I missed summat...
martin42
« Reply #12 on: 09 May 2014, 16:53:56 »
Well thats the leaflet i found in the paper work,after some looking and searching it has a stag 4 ecu system  ;D
Also it has the same fuel gauge that it shows for the stag lpg system.
martin42
« Reply #13 on: 09 May 2014, 16:57:40 »
Petrol gauge over 1/4 tank,put £15 in on way back from finmere tuesday night,put £15 lpg in wednesday night,going to force start it on lpg only for next few days to see if the lpg gauge does drop.
hotel21
  • The Kingdom of Fife
« Reply #14 on: 09 May 2014, 18:49:44 »
 ;D:y
