Author Topic: diesel Omega requires Fuel Drain off pipes  (Read 1314 times)
dutyfree2833
  • United Kingdom
    • Saab
« on: 11 May 2014, 16:51:31 »
Hi
I'm looking at buying a 2002 Omega saloon diesel and have been told that FUEL DRAIN OFF PIPES REQ RENEWING. ( IF NOT                            STARTED DAILY OR EVERY OTHER DAY WILL REQ BLEEDING Or EASY START (?)
Is this a big job and how much should I expect to pay a local garage for parts and labour?  Thanks in anticipation.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: diesel Omega requires Fuel Drain off pipes
« Reply #1 on: 11 May 2014, 17:01:55 »
Hi
No, if it's a TD, & no idea how much, (if a 2.2 no info)  but probably no more that £50. :y
Edit: As it's 2002 it will be a 2.2 so am unable to advise.
« Last Edit: 11 May 2014, 17:05:35 by Shackeng »
« Reply #2 on: 11 May 2014, 17:09:47 »
Hi
Check how often it has been started using "easy start" .. if more than a tiny few... walk as that muck wrecks engines ..... :(
« Reply #3 on: 11 May 2014, 17:18:28 »
Could be a number of things not just fuel pipes
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #4 on: 13 May 2014, 16:28:47 »
Hi
Poor compression due to severely damaged combustion chambers? >:(
Best get the seller to change the leak-off pipes ... or simply walk away ... IME ;)
