Author Topic: 19" wheels  (Read 3884 times)
capoMV6
19" wheels
« on: 12 May 2014, 03:50:48 »
Am replacing my wheels from the standard 17" and upgrade to 19". Is there any adjustment or replacement I need to do with the underchassis or suspension? Also will the series 40 tyre be perfect with it? TIA
chrisgixer
Re: 19" wheels
« Reply #1 on: 12 May 2014, 09:37:27 »
Can't remember the sizes but you need to be careful the outside diameter of the tyre doesn't foul the spring cup on the shock that's sited above the tread.
Also re the width, with a 245 wide tyre max, et needs to be within et38 to et30 to avoid strut and wheel arch liner rubbing with camber set to -1.10 . Even then be weary of some tyres with massive rim protection. Such as Bridgestone potenza 010.
Bolt pattern is 110mm
Other than that its plug and play. :)
I would advise though, that with the inevitable lower profile tyre you'll need , the ride will become much harsher. Personally wouldn't go more than 18" for that reason, especially with the roads in such a poor state ATM.
Re: 19" wheels
« Reply #2 on: 12 May 2014, 09:50:27 »
A 40 profile with a 19" 235/245 tyre may knock the speedo out a fair way.  You may have to go down to 35, which will make the ride less desirable.
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: 19" wheels
« Reply #3 on: 12 May 2014, 10:09:49 »
im running 225-40-18 on my mv6 & trust me its very hard.  :)
Re: 19" wheels
« Reply #4 on: 12 May 2014, 10:29:14 »
Not surprised, those tyres are on the narrow side... 235/245 recommended  :y
Re: 19" wheels
« Reply #5 on: 12 May 2014, 10:33:30 »
When the time comes to replace, worth going a bit wider, to increase the height of the rubber, which will take some of the harshness out (not as much as going back to 235/45/17 though).  Its finding whats good for you, which isn't cheap, given tyre prices.
The Red Baron
Re: 19" wheels
« Reply #6 on: 12 May 2014, 10:37:44 »
you aint kidding j, amazing how the prices differ on such a small size change.
capoMV6
Re: 19" wheels
« Reply #7 on: 12 May 2014, 11:09:53 »
Planning to fit 225x45x19 tyres. anything I should worry about? Thanks
Re: 19" wheels
« Reply #8 on: 12 May 2014, 11:31:23 »
What width rim, as that's an awfully narrow tyre :o
Additionally, the rolling diameter will be a lot larger, so all instruments will be out.
martin42
Re: 19" wheels
« Reply #9 on: 12 May 2014, 12:35:59 »
Must be going for the euro look with excessive camber  ;D
Re: 19" wheels
« Reply #10 on: 12 May 2014, 12:51:53 »
I always wonder are bigger wheels an 'upgrade'?
They cost more for new tyres, generally make the ride worse for comfort and take a lot of suspension fiddling.
Are you going for 19, purely for looks?
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: 19" wheels
« Reply #11 on: 12 May 2014, 13:50:00 »
you mean 19" wheels and 18" tyres. Its wot da youff is duoing naow in-it.. :-X
Hoof'land storeman.
chrisgixer
Re: 19" wheels
« Reply #12 on: 12 May 2014, 19:12:51 »
There's a balance to be had IMO. 16" sidewalls are too squidgy IMO. 17" are better, but 18" take out a lot of the ballon effect from directional stability of a tyre sidewall.
But on the other hand, as the wheel gets bigger, the tyre MUST get lower profile. And as tyre is the first point of the suspension, low frequency bumps and small road imperfections come through more.
Ime an 18" on sc3 245 40 18 at 28-30 psi, depending on ambient temp, is spot on.
....for me. ;)
However, given the state of the roads, and some steady driving, a yearning for a fractionally softer ride comes in, as I'm currently running 34psi in case I hit a pot hole.
If tyre cost is an issue, then choose a wheel that give the most common style size. ;)
For the op, I'm fairly sure you need to be 35 profile or under on a 19" rim to avoid fouling the spring cup.
But as said, what width rim, and what ET?
chrisgixer
Re: 19" wheels
« Reply #13 on: 12 May 2014, 19:19:26 »
Ps, if you want to see the result of too big a wheel/too low a tyre profile, google the Australian top gear uTube vid of the Holden commadore gts on their test track.
The 19" wheel gave less tyre squeal than the 20" wheel which had a slower lap time. But the 20" wheel had room for mahooosiv brakes. (Which are less effective due to the lower profile tyres) Commadore takes a much bigger rolling circumference than omega, so a generally taller side wall is used, btw. ;)
Re: 19" wheels
« Reply #14 on: 12 May 2014, 20:05:39 »
apart from cost,  you will soon end up with problems.. which may cost more money to solve..
Page created in 0.023 seconds with 16 queries.
