Author Topic: Audible sound / squeak when removing key from ignition ?  (Read 8356 times)
PAULCDX
Hi,
Forgive me if this post is in the wrong section.  :-[
I'll try and describe the problem the best I can.
When I remove the key from the ignition after every drive I get what I can only describe as a very short audible sound which starts off loud then fades out within seconds. I'm sure it's coming from the ignition barrel or somewhere near ?  :-\
This happens when I take the key out the ignition and before I set any alarms or lock the car etc.  ???
I probably haven't described this very well but hopefully somebody may have an idea what this could be or had a similar experience.
Thanks in advance for any advice.
Paul  :y
martin42
Re: Audible sound / squeak when removing key from ignition ?
« Reply #1 on: 15 May 2014, 19:25:37 »
Do you still have the power sounder fitted?
PAULCDX
« Reply #2 on: 15 May 2014, 19:33:11 »
Not sure to be honest as I haven't had the car long. Not sure what I'm looking for  :-[
If it is connected could it be this? Just wondered why it happens after key removal ?  :-\
« Reply #3 on: 15 May 2014, 19:39:00 »
think i know what sound you mean , i heard it today on mine as i took the key out ignition . It sounds like a squeaky toy but quieter  :y
Maybe just the audible open door alarm not sounding properly .
« Last Edit: 15 May 2014, 19:40:42 by Emd »
PAULCDX
« Reply #4 on: 15 May 2014, 19:47:03 »
Could be but it sounds when the door is closed and the key removed.  :-\
« Reply #5 on: 15 May 2014, 20:58:29 »
Power sounder lives under the driver's side of the wiper scuttle ............. http://www.omegaowners.com/forum/index.php?topic=90675.0  :y They do chirp as they die/about to die  ;)
PAULCDX
« Reply #6 on: 15 May 2014, 21:32:26 »
Haven't heard any chirps at all but could it sound when I'm taking the key out the ignition ?
Guess it's best to get it disconnected if it hasn't been done already and then see if the sound is still there on key removal
« Reply #7 on: 15 May 2014, 22:21:33 »
Lights on/key in warning buzzer losing a static charge would be my guess, but don't ask me how or why it happens  :-[
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #8 on: 16 May 2014, 11:01:23 »
Power sounder gives a noise when keys put in and power applied, not when taken out and power removed - highly unlikely to be that   ;)
Radio & Decoding Technician
www.dndservices.co.uk
« Reply #9 on: 16 May 2014, 11:35:20 »
Nope, power sounder give a number of beeps on key removal from ignition  :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #10 on: 16 May 2014, 12:53:54 »
Hi,
When I remove the key from the ignition after every drive I get what I can only describe as a very short audible sound which starts off loud then fades out within seconds. I'm sure it's coming from the ignition barrel or somewhere near :-\
Paul  :y
Does it have a after market HU fitted?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #11 on: 16 May 2014, 14:53:37 »
Makes sense that  :y
I get the same thing on my Mv6
Standard 2013 head unit and the power sounder is removed
PAULCDX
« Reply #12 on: 16 May 2014, 21:11:20 »
Not sure if powersounder has been removed but I still need to check when I get 5 mins  ::)
My car had a CCR2006 fitted and now has a sony aux CD player which was fitted last week. Nothing to do with that is it ?  ;D
« Reply #13 on: 16 May 2014, 21:27:11 »
It sounds like an MV thing  ::) Mine has aftermarket HU also  :(
« Reply #14 on: 16 May 2014, 21:27:39 »
I had an Astra G that came with an after market head unit in it ...... that used to do a strange chirp of sorts when the key was removed. Sorted with a GM head unit. (it was a while ago no so details are a little misty now  ::))
« Last Edit: 16 May 2014, 21:29:33 by Andy B »
Page created in 0.014 seconds with 15 queries.
