Author Topic: Omega 2.2 (Z22XE) Non starter  (Read 1286 times)
GSD
  • kent
    • Omega 2.2cdx auto est
« on: 17 May 2014, 00:24:11 »
Hello after some help if poss? 2001 omega 2.2 petrol estate had misfire and was going into limp mode when started,replaced coil pack rubbers with new,cleaned out throttle and breathers and replaced camshaft sensor (genuine Vauxhall parts) now it will not make any attempt to fire,turns over fine,almost like imobiliser is cutting in but eml light not flashing,have tried both keys and re-synced keys as well,left battery disconnected overnight to see if this helped,still not starting can anybody give me some suggestions to get the poor old girl running again???? :'( :'(
Re: Omega 2.2 (Z22XE) Non starter
« Reply #1 on: 17 May 2014, 01:11:48 »
See if you can get codes mate - http://www.omegaowners.com/forum/index.php?topic=90581.0
Does sound like it could be duff crank sensor ;)
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
« Reply #2 on: 17 May 2014, 08:26:45 »
Have you checked the connections of what you've disconnected, I only ask cause I've done it myself ::)
