Author Topic: Disc Brake Bolts  (Read 1266 times)
frmg0014
  • Brampton, Ontario, CANADA
    • 2001 Opel Omega MV6
Disc Brake Bolts
« on: 17 May 2014, 11:53:45 »
Anyone know the thread and size of the bolt that holds each disc brake in place (2001 Omega MV6)?  I managed to round mine off a while back.  Currently not running with them on, but what a pain in the rear to put the wheels on without them  >:(
I'm about to do a complete brake overhaul along with GTO calipers, new pads and disc all around..might as well get this sorted out!  :y :y :y
Re: Disc Brake Bolts
« Reply #1 on: 17 May 2014, 12:14:20 »
Fronts are M6 .... not sure how long probably about 5 or 6mm
I never had the rear disc/drum off  :-\
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #2 on: 17 May 2014, 12:23:39 »
Same from memory.
« Reply #3 on: 17 May 2014, 13:10:11 »
The allen/hex bolts are the same all round. They should only be done up finger tight, as wheelbolts are the real fixing.
