Author Topic: error code  (Read 2545 times)
mickyboy123
  • brighton
  • hi
    • 2.2 cd omega.petrol auto
error code
« on: 19 May 2014, 17:55:38 »
hi chaps, after a lot of trying with pedal trick without any luck, i resorted to buyin a code reader once again no luck wouldnt connect to the car. i finaly resorted to a garage and 50 pound to read code, as follows, PO340 camshaft position sensor no signal intermitant, my question is when i start the car sometimes the engine managment light comes on but if i turn of and restart its okay now i gues that this is the intermitant cam sensor fault. but i also have a permenent problem the car wont pull much past 3 and a half thousand revs. is could the cam sensor do that or do i have another problem :y
Re: error code
« Reply #1 on: 19 May 2014, 18:00:06 »
As code indicates can sensor problem  :y
Genuine only part to be used here  :y
mickyboy123
  • brighton
  • hi
Re: error code
« Reply #3 on: 19 May 2014, 18:16:53 »
okay thanx guys, you put my mind at rest im just woried it was another problem and it might be terminal
mickyboy123
  • brighton
  • hi
Re: error code
« Reply #4 on: 19 May 2014, 20:04:45 »
does 140 sound a fair price to have it fitted by a vauxhall main dealer thats all in including part :)
Re: error code
« Reply #5 on: 19 May 2014, 20:18:31 »
Its a very simple job to fit yourself  :y
mickyboy123
  • brighton
  • hi
Re: error code
« Reply #6 on: 19 May 2014, 20:29:29 »
 how simple is a job for a novice. :o
Re: error code
« Reply #7 on: 19 May 2014, 21:51:27 »
15mm spanner on aux belt. Few torx bolts for belt cover. Diddly bolt for sensor :)
mickyboy123
  • brighton
  • hi
Re: error code
« Reply #8 on: 20 May 2014, 06:47:47 »
blimey that sounds easy i will try it myself i think .today if i can get the part, :y
Re: error code
« Reply #9 on: 20 May 2014, 07:01:35 »
mickyboy123
  • brighton
  • hi
Re: error code
« Reply #10 on: 20 May 2014, 09:35:31 »
thanx for the guide rob, looks straitforwd. part has just arived . and as soon as i have finished my tea im of to get stuck in, will report back latter :y
mickyboy123
  • brighton
  • hi
Re: error code
« Reply #11 on: 20 May 2014, 18:09:52 »
hi chaps, job done it goes like a dream now. everything is difrent gear change smother. tick over smother got twice as much pull and it over takes like a rocket. i am well pleased. thanks guys for all your help. job was fairly easy took 3 hours but why rush :y
Re: error code
« Reply #12 on: 20 May 2014, 18:45:27 »
That include a two and half hour lunchbreak ::) ::) :y
mickyboy123
  • brighton
  • hi
Re: error code
« Reply #13 on: 20 May 2014, 19:01:18 »
no but did spend a lot of time drinking tea  :y
Page created in 0.019 seconds with 14 queries.
