Pages: 1 [2] 3  All   Go Down
Author Topic: Weller TCP-Z irons  (Read 8645 times)
Re: Weller TCP-Z irons
« Reply #15 on: 24 May 2014, 21:37:10 »
A good belt on the ground has (temporarily, I suspect) fixed the problem.
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #16 on: 24 May 2014, 21:51:29 »
Bet you used to slap tellies and call em fixed too. ;D
TuBy's new whipping boy.
« Reply #17 on: 24 May 2014, 21:53:10 »
Is that not the correct repair technique? ;D
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #18 on: 24 May 2014, 21:56:31 »
Did you have the same ex-rumbellows tutor as us then?
« Reply #19 on: 24 May 2014, 22:06:03 »
I had a very good one TBH, hence even a stupid kid like me walked out with distinctions in all exams :).  Obviously, all based on G11 and TX10 era chassis, so not much use now ;D
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #20 on: 24 May 2014, 22:10:30 »
Did my practical fault finding exam on the Fergy TX. OC resistor or a shorted cap was about all the faults they could afford to put on so it was pretty simple to fault find.
  • Auckland
    • Mazda MPV
« Reply #21 on: 25 May 2014, 09:00:40 »
Is this the part?
Farnell - Weller TCP switch
£29.29 (+ tax & postage....)
Mine doesn't look like that...
Going by Weller Magnastat Datasheet the TCP-Z uses zero point switching.
Does your iron have a circuit board in the power supply? or are the electronics part of the thermostat?
I wouldn't be surprised if the thermostat was OK but a 20 year old capacitor has failed on the circuit board.
« Reply #22 on: 25 May 2014, 09:11:23 »
Well spotted. Forgot it was a TCP-Z we're talking about. I'm guessing it still has a mechanical switch in the iron, though, and given that a sharp tap fixed it...
« Reply #23 on: 25 May 2014, 09:20:04 »
Switch is in iron, circuit board longer than in pic. In use, you can feel it switch.
« Reply #24 on: 25 May 2014, 09:24:22 »
Guess it just has a zero volt switching triac circuit in the handle. Exactly what I want to do to mine, in fact.
« Reply #25 on: 25 May 2014, 09:26:22 »
I couldn't see what it was without lifting it off, but there was a 3 pin solid state device on the board in the handle, so could well be :y
chrisgixer
« Reply #26 on: 25 May 2014, 09:37:24 »
 I have an image of TB swinging the poor article by its power lead, for a damn good thrashing ;D
chrisgixer
« Reply #27 on: 25 May 2014, 09:38:46 »
Mum bus must have a use of some sort, surely?
« Reply #28 on: 25 May 2014, 10:07:01 »
How can that fix my soldering iron?  :-\
Have you been on STEMO's meds?
chrisgixer
« Reply #29 on: 25 May 2014, 10:11:02 »
Well you could beat it with your soldering iron? ;D
Pages: 1 [2] 3  All   Go Up
Page created in 0.025 seconds with 20 queries.
