Pages: [1] 2 3  All   Go Down
Author Topic: Weller TCP-Z irons  (Read 8720 times)
Weller TCP-Z irons
« on: 21 May 2014, 22:13:02 »
Suspect its stuck on, as overheats.
Is it part of element assembly, or a separate switch?
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
Re: Weller TCP-Z irons
« Reply #1 on: 21 May 2014, 22:47:46 »
Matchless
  • Nottingham
    • A white van
« Reply #2 on: 21 May 2014, 23:04:59 »
If you twiddle your tip daily as you are supposed to then it doesnt get stuck. Is your end glowing red?
The thermostat works by magnetics, it is attracted to the tip closing a switch. As the temp rises above the curie point the magnetic attraction is overcome by spring force and the contacts separate. The tip and thermostat on your iron are probably stuck together by rust or corrosion so the contacts are closed permanently.
These irons were common in the 70's but be careful using them on modern high speed / low voltage electronics, they create a massive emc pulse when switching and can destroy small geometry parts. We used to use them for finding holes in the emc protection of fibre receivers.
« Reply #3 on: 22 May 2014, 10:37:46 »
What he said ^.
You can get replacement switches and they are easy enough to change. Sometimes you can free them up by aforementioned tip-twiddling, though.
I wouldn't be without a Weller TCP.  :y
  • Online Online
« Reply #4 on: 22 May 2014, 11:13:29 »
When I saw the title I thought TB's hair straighteners had packed up!  :D  ;D
« Reply #5 on: 22 May 2014, 11:16:09 »
I had to google to figure out if this was a pink or blue repair job, too.. ;D
Stemo
« Reply #6 on: 22 May 2014, 12:56:36 »
OOOOOOO you are awful.........but I like you  :-*
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #7 on: 22 May 2014, 21:17:05 »
Mmm bet fathers got 1 or two of them in tut barn,unless the owls have poo'd all over them. :)
Hoof'land storeman.
« Reply #8 on: 22 May 2014, 21:31:05 »
I've replaced the bit, and it doesn't seem too corroded. It gets hot enough that both the bit and the end of the tube glow.
Is the switch obvious, wondering if the contacts have welded...
Bigron
  • Witham, Essex
« Reply #9 on: 22 May 2014, 22:05:22 »
TB, you might consider updating your iron. I used to use loads of that model when lecturing in Electronics at college, some years back, but marvellous though they were, they have been superseded by much superior electronically controlled irons, much more suited to the work that Matchless referred to.
However, if you insist on saving your present one, they are easy enough to dismantle.
When they were owned by Cooper Tools, spares were plentiful, but since 2010, I think, another large company joined with them and I no longer have dealing with them so don't know the spares position......
Ron.
  • Auckland
    • Mazda MPV
« Reply #10 on: 22 May 2014, 23:04:01 »
Is this the part?
Farnell - Weller TCP switch
£29.29 (+ tax & postage....)
« Reply #11 on: 23 May 2014, 11:21:01 »
Is this the part?
Yep, that looks familiar, but I'm sure there are cheaper sources. Ebay is worth a look.
« Reply #12 on: 23 May 2014, 11:45:53 »
Actually, I keep meaning to see if I can shoe-horn a triac into my irons to take the load off the switch. That may make it last better.
  • Auckland
    • Mazda MPV
« Reply #13 on: 23 May 2014, 13:02:43 »
Zero point switching might even reduce (or eliminate) the spikes Bigron reported :y
« Reply #14 on: 24 May 2014, 21:35:01 »
Is this the part?
Mine doesn't look like that...
Pages: [1] 2 3  All   Go Up
