Author Topic: rear axle  (Read 1199 times)
mickyboy123
  • brighton
  • hi
    • 2.2 cd omega.petrol auto
rear axle
« on: 22 May 2014, 15:57:39 »
hi chaps, does anyone know of hand if a 2.2 .02 plate has a drain plug on the rear axle or do you have to take the back plate off.  ???
chrisgixer
Re: rear axle
« Reply #1 on: 22 May 2014, 16:04:34 »
Dif has a fill plug, but not a drain which means plate off. There is a guide iirc.
Re: rear axle
« Reply #2 on: 22 May 2014, 16:51:04 »
You might be able to suck most of the oil out using an oil extractor.
You can also drill the casting to convert the bottom backplate bolt into a drain plug, but you need to take the late off first.
That said, unless it's a limited slip, there's no real reason to change the oil.
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
Re: rear axle
« Reply #3 on: 22 May 2014, 19:18:02 »
I used an oil extractor to change my diff oil and afterwards when I filled it back up it took the full 1 litre of oil. So it must of sucked it all out.  :y
The back of the car was jacked up when I extracted the oil, so this may of been why it sucked all the oil out. The car was lowered to the floor when I filled with mew oil.
« Last Edit: 22 May 2014, 19:33:10 by Andy A »
Andy A
  • Bristol UK
Re: rear axle
« Reply #4 on: 22 May 2014, 19:33:36 »
