Author Topic: setting headlights for abroad  (Read 2902 times)
Arpy
  • Preston
  • 02 2.2 cdx estate auto
« on: 25 May 2014, 13:45:17 »
Hi
Recently been travelling to france but just keep getting confused with the settings for the HID headlights
there is a little lever to shift a little plate in front of lamp. so for this country as you are looking at the car what should the left light be set at plate up or no plate
and the right head light plate up or plate down
I am thinking no plate for uk and both plates for francais???
Help
Varche
  • middle of Andalucia
    • Golf Estate
Re: setting headlights for abroad
« Reply #1 on: 25 May 2014, 16:38:03 »
Lever position for Europe driving of a UK car is:
Driver lever up, passenger lever Down
Arpy
  • Preston
« Reply #2 on: 25 May 2014, 16:53:18 »
thanks will sort that out tonight when dark just for curiosity is the plate blocking the passenger light
« Reply #3 on: 25 May 2014, 20:41:26 »
The levers blank off the kick-up on both headlamps, making it effectively a lower beam.
Arpy
  • Preston
« Reply #4 on: 25 May 2014, 20:45:29 »
ah
so if I have understood correctly the passenger should have the plate up to stop dazzling the frenchies when I drive on the wrong side of the road!!!!
« Reply #5 on: 25 May 2014, 20:51:25 »
ah
Both sides need to have the kick-up blanked. Both sides.
From memory, that means one lever up, other down, as explained in the user manual.
« Reply #6 on: 25 May 2014, 21:01:04 »
ah
Drive up to a wall/garage door when it gets dark. Lights on & before you alter anything, you'll see \_____   \_____ on the wall/door. Alter the levers up & down, you'll mask the left hand upsweep & end up with  ______   ______  :y
« Last Edit: 25 May 2014, 21:03:44 by Andy B »
« Reply #7 on: 26 May 2014, 13:35:58 »
ah
I need to set mine for euroland soon.  If only I could find a garage door ;D
« Reply #8 on: 26 May 2014, 13:56:11 »
 ;D ;D ;D ;D ;D ;D ;D ;D
