Author Topic: Dreary extension lead question  (Read 3364 times)
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« on: 25 May 2014, 20:10:01 »
Due to having a bigger, more lavishly bordered* garden than I've ever had before, I need an extension lead to power the hedgetrimmer. To give me enough length to run it out of the kitchen, down the garden, round the neighbour's cat's neck, I reckon 25m. Is there anything to look for when I buy one? I shall, of course, be unfurling the full length of it before use so as not to melt it.
 Do Aldi get them in, maybe? Or are they all much of a muchness in terms of quality?
*It's long and thin with a massive bush. Like Trinny Woodall when she lets herself go.
Re: Dreary extension lead question
« Reply #1 on: 25 May 2014, 20:33:41 »
A cordless or petrol version ::)
chrisgixer
« Reply #2 on: 25 May 2014, 21:24:02 »
Is it really necessary to pull out all (of my 50metre ) extension cord, every time is use 10metres of it?
I guess the fact that the last time I pulled out 30odd metres and the cord was slightly stuck together, would suggest yes, it is. ::) ;D
I never wondered why. ;D
« Reply #3 on: 25 May 2014, 21:25:21 »
Not if you're only running a hedge trimmer. A more substantial load, then yes.
chrisgixer
« Reply #4 on: 25 May 2014, 21:26:01 »
Tyre warmers? It was a while ago.
tidla
  • solihull
« Reply #5 on: 25 May 2014, 22:26:32 »
The only thing i manage to trim when using an electric hedge trimmer is the power cord..
  • Online Online
« Reply #6 on: 25 May 2014, 22:57:10 »
likewise ..... done it quite a few times now. You'd think I'd have learned by now  ;D ;D
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #7 on: 25 May 2014, 23:09:48 »
Lay some cable and put in power points / spikes as longer term measure. Otherwise petrol.
« Reply #8 on: 25 May 2014, 23:58:27 »
If right handed, put the power cable over your left shoulder, should help........ :y :y
tidla
  • solihull
« Reply #9 on: 26 May 2014, 00:15:35 »
probably end up cutting my head off .
chrisgixer
« Reply #10 on: 26 May 2014, 00:22:54 »
;D ;D
« Reply #11 on: 26 May 2014, 01:06:38 »
I can see this thread extending somewhat....  :-\
  • Online Online
« Reply #12 on: 26 May 2014, 08:29:02 »
I do. Incompetence still prevails though  ::)
« Reply #13 on: 26 May 2014, 09:32:57 »
I'd get a petrol one, but the extension lead will also be useful for plugging in stereos and grinders and the like - whereas getting a new hedgetrimmed would be pretty much a one trick pony. Until they legalise me chasing cats out of the garden with it...
« Reply #14 on: 26 May 2014, 10:04:14 »
Ideally, all coiled leads *should* be fully unwound when plugged in, which may (or may not?) make a 25m one also a 1 trick pony, only used for the hedge trimmer.
Strangely enough, for some bizarre reason, I had a lot of visits from the fire brigade to give advice, and amongst all the other advice were these 2 electrical ones:
Coil extension leads, always fully unwind when plugged in (I always did when actually in use, even if under the wound limit, but they say even when in use).
Never use those 3 way block type mains adapters, to plug more than 1 plug in a single outlet. Not recommended, but if you do need more sockets, use those standard 4 way ones on a short cord, from a reputable manufacturer.
One of the possible reasons for what happened here was a coiled extension lead plugged in when fully wound, even though nothing plugged in.
