Author Topic: Caliper rebuild .....  (Read 2903 times)
minifreek
  • Wigan
    • 2.4 V70 & 94 Mini SPi
« on: 26 May 2014, 20:13:59 »
I have a sticky rear caliper, was an advisory on the MoT and I really need to get it sorted before too long...
Is there a kit to rebuild the caliper or is it easier to just swap 1 for a working item..?
If anyone could post any links or advice for refurbing a rear caliper, would be appreciated...
D.I.L.L.I.G.A.F...
steve6367
Re: Caliper rebuild .....
« Reply #1 on: 26 May 2014, 23:32:22 »
I couldn't see an easy way so just changed mine. Got a good lump of the cost back when I returned the faulty one :-)
chrisgixer
« Reply #2 on: 27 May 2014, 00:00:34 »
Is this Vauxhalls exchange service?
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #3 on: 27 May 2014, 07:53:56 »
Hoof'land storeman.
« Reply #4 on: 27 May 2014, 08:17:09 »
There very simple to swap the seals on but you need to be confident the bore is not pitted from rust (leaking calipers are a sure sign of poor brake fluid maintenence at some point in the vehicles life).
The caliper sets on the Omeag are very reliable so second hand is a good option.
minifreek
  • Wigan
« Reply #5 on: 27 May 2014, 09:44:11 »
What I was thinking of was changing the caliper and rear disc for the vented type as mine hasnt got the vented discs on the rear...
I know they are thicker and the calipers are spaced to accomodate, but mine looks like a Vectra rear caliper....? So Im presuming if it is, I could get a pair from a scrappy, rebuild them both, then fit.... so if they are the same as the Vectra's I would have plenty to source from...
D.I.L.L.I.G.A.F...
steve6367
« Reply #6 on: 27 May 2014, 22:40:16 »
GSF as they had it in stock - VX wanted me to make several days
« Reply #7 on: 28 May 2014, 08:34:42 »
Omega rear calipers are:
Rear-Left; With Solid Discs; (>Ch.) W1069516  Part No: R1740052
Rear-Right; With Solid Discs; (>Ch.) W1069516  Part No: R1740053
Rear-Left; With Solid Discs; (Ch.>) W1069517  Part No: R1740066
Rear-Right; With Solid Discs; (Ch.>) W1069517  Part No: R1740067
Rear-Left; With Vented Discs  Part No: R1740090
Rear-Right; With Vented Discs  Part No: R1740091
For Vectra B, no part numbers match the vented type for the Omega, I cant check the Vectra C ones at the moment
« Reply #8 on: 28 May 2014, 12:10:09 »
Vectra C ones include that farcical self adjusting releasing handbrake mechanism, so I wouldn't bother :y
« Reply #9 on: 28 May 2014, 12:49:22 »
Ah yes, thats right, they went to the Lucas/Bosch rear caliper with the disc handbrake setup  :y
« Reply #10 on: 28 May 2014, 12:53:08 »
And 29 years after some bean counter invented them, they still don't work ;D
And all for ten minutes saved on the assembly line ::)
minifreek
  • Wigan
« Reply #11 on: 28 May 2014, 17:04:44 »
The Vectra caliper/disc combination is different from the vented Omega caliper/disc...
There was at one time a kit you could buy to space the Vectra rear caliper to fit the Omega vented rears... not many bothered with the conversion TBH and just went for the Saab rear vented disc and caliper instead as they are a straight swap....
Thanks for the part numbers though MarkDTM :)
D.I.L.L.I.G.A.F...
Page created in 0.026 seconds with 16 queries.
