Author Topic: Power steering leak  (Read 1614 times)
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
Re: Power steering leak
« Reply #1 on: 27 May 2014, 09:07:52 »
the reservoir pipe with the jubilee clip on
That`s where most of them leak Andy
chrisgixer
« Reply #2 on: 27 May 2014, 09:34:03 »
Probably the jubilee round that top pipe. Not sure why they don't use hose clips like everywhere else on the engine. As jubilees always leak eventually.
Andy A
  • Bristol UK
« Reply #3 on: 27 May 2014, 11:34:20 »
Ok lads, I'll put a new hose clip on, wipe everything down and keep an eye on it.  :y
« Last Edit: 27 May 2014, 11:49:19 by Andy A »
Andy A
  • Bristol UK
« Reply #4 on: 27 May 2014, 12:07:57 »
I didn't realise that the jubilee clip was put there from new.  :o All the ones I've seen in the past are crimp on.
chrisgixer
« Reply #5 on: 27 May 2014, 14:40:55 »
Hmmm, you might be right.
Might be worth checking the reservoir isn't cracked while there. It's only plastic.
Andy A
  • Bristol UK
« Reply #6 on: 28 May 2014, 07:44:22 »
I'll check for cracks as well Chris. Thanks :y
Andy A
  • Bristol UK
« Reply #7 on: 31 May 2014, 08:54:03 »
Spot on Rob & Chris. It was the jubilee clip.  :y
Thanks.  :y
« Last Edit: 31 May 2014, 08:57:45 by Andy A »
