Author Topic: door solenoid  (Read 1267 times)
badmuver
door solenoid
« on: 27 May 2014, 18:13:27 »
I have a question, if the drivers door solenoid was to pack up would it set the alarm off, I have trouble with the drivers door sometimes would not lock   :)
chrisgixer
Re: door solenoid
« Reply #1 on: 27 May 2014, 18:22:20 »
No. But the alarm will go off if the door is unlocked via the key.
badmuver
Re: door solenoid
« Reply #2 on: 27 May 2014, 18:45:03 »
i have to leave it unlocked at the moment as the alarm goes off  >:(
chrisgixer
Re: door solenoid
« Reply #3 on: 27 May 2014, 18:48:41 »
Are the indicators all flashing when it goes off?
badmuver
Re: door solenoid
« Reply #4 on: 27 May 2014, 18:52:45 »
yep and noisy  ;D
chrisgixer
Re: door solenoid
« Reply #5 on: 27 May 2014, 19:24:43 »
Might suggest a genuine alarm then. As opposed to a power sounder fault.
Might need tech 2 to find which sensor is tripping it.
But see what others say I'm shite with electrics. :-[ ;D
badmuver
Re: door solenoid
« Reply #6 on: 27 May 2014, 21:54:31 »
same here, anyone with tech 2 east Sussex area  :y
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
Re: door solenoid
« Reply #7 on: 27 May 2014, 22:39:31 »
Can you lock car with key?, if yes, can you unlock it using remote? if so should be ok as i had to do this with mine
for a while due to lazy solenoid. Give it a go.
symes
  • oxford
    • R reg 940 volvo
Re: door solenoid
« Reply #8 on: 27 May 2014, 22:45:32 »
if you take lock/solenoid out--sometimes it plastic lug on top of solenoid becoming dislodge by slamming door--did pas side front week ago :y
chrisgixer
Re: door solenoid
« Reply #9 on: 27 May 2014, 23:18:15 »
Mean time, remove power sounder and horn. To shut it up.
