Author Topic: radio wont turn off  (Read 1124 times)
baznrosie
radio wont turn off
« on: 28 May 2014, 23:55:55 »
ive got a omega elite 1999, its been stood for 2 years, bought a new battery for it, it started up after a couple of turns. then i put the code in for my radio and  got that going. the problem was when i turned the engine off and took the key out of the iignition the radio stays on , and you cant turn it off manually neither. could anyone help with this problem.
        Baz
Re: radio wont turn off
« Reply #1 on: 29 May 2014, 10:52:39 »
        Baz
Does it play Rick Astley 24/7?. That would be heaven to some on here. :y
I'm sure that someone will be along to help. :y
baznrosie
« Reply #2 on: 30 May 2014, 01:21:31 »
well thanks for that as i dont no who rick astley is,,,,,,,as yet no one as come along yet to help, :y        baz
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
« Reply #3 on: 30 May 2014, 08:18:51 »
Do a new topic, in the Omega Electrical and Audio Help section.  :y
« Reply #4 on: 30 May 2014, 09:52:07 »
What radio is it? A 1999 Elite could have the highly strung CCRT700 unit in, or a reasonably reliable (if you don't use CDRs) CCR2006 in it.
Esp if its a CCRT700, I'd try removing the radio from the car for 2hrs, then retrying.
One last check:
Ign On
Ign Off, but do not remove key
Open drivers door - does warning buzzer go off?
Then (after closing door):
Ign On
Ign Off and key removed
