Author Topic: front fog light  (Read 3183 times)
aiden
  • middx
    • omega cdx estate
front fog light
« on: 29 May 2014, 11:49:00 »
hi guys
           front fog light works but has a broken glass is it an mot fail, cheers
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: front fog light
« Reply #1 on: 29 May 2014, 12:35:09 »
Yes think so
Keith ABS
  • Maldon Essex
Re: front fog light
« Reply #2 on: 29 May 2014, 12:52:09 »
I thought front fogs were not motable as they are not fitted to every car as standard like the rears. I wait to be corrected
Keith b
GastronomicKleptomaniac
  • Online Online
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Re: front fog light
« Reply #3 on: 29 May 2014, 13:05:21 »
Keith b
Correct - won't fail, unless there's sharp edges that could injure. In this case, only if you regularly drive past Wonka's chocolate factory...
Re: front fog light
« Reply #4 on: 29 May 2014, 13:05:55 »
I believe that if fitted the glass must be intact otherwise it is deemed a safety hazard to pedestrians should you touch one .. :(
Easiest solution is to simply remove the broken light unit completely for the MOT  :)
Re: front fog light
« Reply #5 on: 29 May 2014, 13:08:30 »
Pop both off and they won't even attract an advisory :y
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
Re: front fog light
« Reply #6 on: 29 May 2014, 13:16:13 »
Agreed, Al.
My recollection is that non-obligatory lights, if fitted, must function and be fitted in pairs, equally disposed about the centre line of the vehicle - so remove both.
As foglights are an option, removing them will not attract comment.
Ron.
omegod
  • liverpool
    • 2017 Seat Ateca
Re: front fog light
« Reply #7 on: 29 May 2014, 18:41:38 »
Had the same with the Saab, tester said pop some tape over it and it will be fine
Re: front fog light
« Reply #8 on: 29 May 2014, 19:16:22 »
Agreed, Al.
My recollection is that non-obligatory lights, if fitted, must function and be fitted in pairs,  ....
'My' MOT tester has never ever even turned my front fogs on on any car I've taken for MOT so I assume that they don't need to function
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: front fog light
« Reply #9 on: 29 May 2014, 19:51:13 »
Although your tester might not check. If its on the car it must work at time of inspection. If glass is cracked in lens as long as its not dangerous if someone touched it then its fine
Re: front fog light
« Reply #10 on: 29 May 2014, 20:48:38 »
http://www.motuk.co.uk/manual_110.htm
Additional or optional lamps are not included in the inspection.  ;)
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: front fog light
« Reply #11 on: 29 May 2014, 20:56:02 »
might be optional but will still fail if the glass is cracked and has sharp edges in the lens
Re: front fog light
« Reply #12 on: 29 May 2014, 20:57:22 »
Agreed! But it's not required to work  ;)
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: front fog light
« Reply #13 on: 29 May 2014, 21:12:15 »
smart arse  :y
Re: front fog light
« Reply #14 on: 29 May 2014, 21:54:54 »
