Pages: [1] 2 3  All   Go Down
Author Topic: NCDC2013 multiple CD player not working  (Read 11806 times)
Lagondanet
  • Bedfordshire
  • The Omega is gone!
    • Lagondanet
« on: 30 May 2014, 10:26:02 »
The multiple player (4 disc) is not working and shows disc error. The single CD drive is OK with both music & satnav.
I had this problem with my last Omega & Radio Solutions in Luton fitted new drives but they say parts are no longer available and suggest I look for an entire working second hand unit (NCDC2013) plus its code & fit that.
Is that the way forward? Anyone got one?
Re: NCDC2013 multiple CD player not working
« Reply #1 on: 30 May 2014, 10:45:25 »
That is the only solution.
I had bundles of them, but lost them in the garage, single handedly wiping out the worlds supply ;D
I have a handful left, but they are not for sale, they are for use for spares for mine.
Finding good units with working lasers now is getting difficult, as the explosion in CDRs a few years ago, means most of these units have had a hard life. Poorly burned CDRs wreck these units. Even well burned CDRs, done with quality media, at slow speed, on a good writer, do these units no favours.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 30 May 2014, 10:57:25 »
Is the required lasor not used in other GM heads?
Hoof'land storeman.
    • 530D M Sport, 330i Coupe
« Reply #3 on: 30 May 2014, 11:03:15 »
Not quite  :-X
« Reply #4 on: 30 May 2014, 11:48:45 »
Surely a working CDC3 would suffice as opposed to a complete HU ???
« Reply #5 on: 30 May 2014, 14:36:02 »
Ah, sorry, I thought that was what the OP meant  :-[
OP - what you need, if you can find one, is a CDC3, either as a standalone unit or as part of a NCDC, CCR2006, CCRT2008 etc, *but* you must use your original vertical board in it.
« Reply #6 on: 30 May 2014, 14:36:58 »
My point earlier is there are not many CDC3s (either standalone or as part of a double din unit) that haven't had a hard life...
Lagondanet
  • Bedfordshire
    • Lagondanet
« Reply #7 on: 30 May 2014, 14:52:53 »
Point taken gentlemen but has anyone got it/them they would care to part with?
« Reply #8 on: 30 May 2014, 15:08:32 »
Got a working CDC3 but it`s part & parcel of a CCR2006
Lagondanet
  • Bedfordshire
    • Lagondanet
« Reply #9 on: 30 May 2014, 21:34:35 »
Is this a job I can do myself (with my five thumbs)? Is the CD drive plug-in, as opposed to soldered? If the NCDC2013 unit is divorced/factory reset does the car just assume its identity or is a code required? Does just putting in the CDC3 drive require a code reset? As you might have surmised I am not teccy at all.
 ;D
« Reply #10 on: 30 May 2014, 21:36:32 »
Yep
CD drive plug-in
Yep
Nope
http://www.omegaowners.com/forum/index.php?topic=90608.0
Lagondanet
  • Bedfordshire
    • Lagondanet
« Reply #11 on: 30 May 2014, 21:38:59 »
Yep
CD drive plug-in
Yep
Nope
Thank you RobG for your info & vote of confidence. I owe you a pint. Now how many times have I said that?
 :D
« Reply #12 on: 30 May 2014, 21:41:30 »
Takes me about 10 minutes to remove HU, strip & re-fit a CDC3, and slot back in the car so you shouldn`t have much of a problem once you`ve sourced a known good one
Lagondanet
  • Bedfordshire
    • Lagondanet
« Reply #13 on: 30 May 2014, 21:45:04 »
Well remind me when we meet that I do owe you that pint! I shall report later.
« Reply #14 on: 31 May 2014, 09:03:36 »
Its quite an easy task, just ensure (as per guide) to remove the nuts from rear and all 4 screws from front before separating.  The vertical board that needs to be swapped is quite fiddly the first time you do it.
Not sure where in Beds you are, but I'm on Bucks/Northants/Oxon border if you need a hand.
Pages: [1] 2 3  All   Go Up
