Author Topic: This must be a joke..  (Read 1078 times)
« on: 16 June 2008, 15:41:51 »
Diesels converted to LPG.. :o
(mmm half LPG).. ;D
http://www.diesellpg.co.uk/
« Last Edit: 16 June 2008, 15:43:33 by cem_devecioglu »
Re: This must be a joke..
« Reply #1 on: 16 June 2008, 15:43:58 »
you can proportionally run diesels on LPG
see www.tinleytech.co.uk
FRE07962128
« Reply #2 on: 16 June 2008, 16:27:14 »
I am aware of diesel vans belonging to the electricity or gas board (can't remember which now) in Bristol some years ago being converted to LPG / Diesel fuel. Therefore I do not think this article is a joke but seriously intended. :y :y
Growler
« Reply #3 on: 16 June 2008, 17:26:23 »
yeah you can run diesel vehicles on LPG but not in the same way as Petrol vehicles.
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #4 on: 16 June 2008, 18:17:01 »
I was working on a project coverting Diesels to run on LPG about 8 years ago for the North Yorkshire Police
They go well on the gas, use a 30/70 mix of diesel/LPG and away you go.
Also give a massive boost in power...
Bandit127
« Reply #5 on: 16 June 2008, 18:34:55 »
You can happily run a diesel on 5% petrol. So if you do inadvertently put some petrol you diesel , as long as it's just a bit you are safe.
I did exactly that on my old '02 BMW 525d. £5 worth of petrol and filled the rest of the tank with diesel and it ran fine. That would be about 7%...
Some people go as far to recommend it every now and then for solvent properties.
I do not know if 5% diesel in a petrol motor will work? Anyone?
« Last Edit: 16 June 2008, 18:35:13 by Bandit127 »
Big Fra
  • Motherwell
« Reply #6 on: 16 June 2008, 18:59:00 »
I have looked into this as well, but as some other posters have said,you dont get the same efficiency as with petrol cars.
So it would take a lot longer to recoup the costs.
I wasn't aware of the boost in power though jon.
« Reply #7 on: 16 June 2008, 19:04:12 »
LPGing a diesel gives big increases in BHP. I go on the diesel section of the MG/Rover forum quite a bit and there was a race on to get 150BHP from a 2.0 Rover diesel. Some people were spending a fortune on Hibred turbos, massive intercoolers, big bore exhausts and chipping and upgraded diesel pumps when all they had to do was add LPG which would cost about £500. The only problem then is replacing the gearbox every few months because of the torque ::)
