Author Topic: DTi test drive results after clutch kit change  (Read 3254 times)
« on: 05 June 2014, 14:15:38 »
The result was:
;D
But I'll give you a clue. Gear change and clutch is now perfect. This is a separate fault.
Anyone guess why she broke down? :y
Re: DTi test drive results after clutch kit change
« Reply #1 on: 05 June 2014, 14:29:16 »
Ran out of fuel?
« Reply #2 on: 05 June 2014, 14:33:08 »
Nope. Something engine wise has failed...
« Reply #3 on: 05 June 2014, 14:35:20 »
Fuel pump or chain :-\
« Reply #4 on: 05 June 2014, 14:41:28 »
Hm.. throttle pedal? Or injection pump as Al says..
BTW what colour is the car? I can't tell if it's that slightly unusual blue or green reflecting the sky.. but it looks quite nice.
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
« Reply #5 on: 05 June 2014, 15:01:11 »
That's my guess to :y
« Reply #6 on: 05 June 2014, 17:37:16 »
Chain suggestion isn't a slur on the previous owner btw :y simply the law of sod... ie that's the sort of shit that happens to me ::)
« Reply #7 on: 05 June 2014, 17:41:42 »
Prop fell off  :-\
Stemo
« Reply #8 on: 05 June 2014, 18:01:55 »
Ermmmm....it's an omega and, therefore, breaks down regularly. :y
    • 530D M Sport, 330i Coupe
« Reply #9 on: 05 June 2014, 18:40:35 »
Oh dear  :'(
I'm guessing fuel pump as the other major failure point on these is crank pulley and that was replaced with a genuine one about 9 months ago. Crank sensor wouldn't stop you limping it home so doubt it's that.
  • Online Online
« Reply #10 on: 05 June 2014, 18:47:09 »
The honeymoon period with your Daewoo will soon be over. You mark my words. ;D ;D
Omegatoy
  • UK
« Reply #11 on: 05 June 2014, 19:17:57 »
hbv? or some type of cooling problem
« Reply #12 on: 05 June 2014, 20:22:44 »
Two last clues, I will reveal later if no correct guesses!
1 it's not chain or pump
2 to get to the offending item I have just removed,
AC compressor
PAS pump
Dipstick tube (what a pig)
And the large bracket which secures all the above....
martin42
« Reply #13 on: 05 June 2014, 20:32:03 »
Oil pump failed
« Reply #14 on: 05 June 2014, 20:33:02 »
Oil Cooler
Engine mount
« Last Edit: 05 June 2014, 20:37:57 by VXL V6 »
Page created in 0.022 seconds with 21 queries.
