Author Topic: Omega 2.2 CDX oil leak  (Read 1502 times)
Gordon1066
  • upper halling kent uk
    • Omega Estate
« on: 05 June 2014, 15:38:22 »
I have an 02 2.2 petrol estate that has developed an oil leak at the front end. It appears to be behind the bottom engine pulley, could it be a crankshaft oil seal that has gone? If so is it hard to replace?
Cheers
Gordon1066
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
Re: Omega 2.2 CDX oil leak
« Reply #1 on: 09 June 2014, 12:12:06 »
Hi Gordon,
Once you have the right tools and providing you can get the crankshaft bolt undone, then it's a easy job to do. Imo.  :y
Good luck with it.
Andy
Andy A
  • Bristol UK
« Reply #2 on: 09 June 2014, 12:32:38 »
Forgot to say that yes it's probably the Crankshaft oil pump oil seal. It was on mine. But make sure that it isn't your Camshaft oil seals first. I understand they do leak and then the oil runs down the front of the engine.
« Last Edit: 09 June 2014, 12:34:38 by Andy A »
Gordon1066
    • Omega Estate
« Reply #3 on: 05 July 2014, 16:38:48 »
Thanks Andy, sorry about the delay in replying, I've been working my rocks off.
