lymph nodes
Started by pauls, 10 June 2014, 21:17:21
pauls
Can you check if cancer has spread to your lymph nodes by using blood tests or a mri scan
Or do you have to have surgery.  I know its a bit of a big question but i want some indepenant answer.
Can you please answer if you know, not what google says. I have read all of that.
ps. If admin thinks this is not the sort of subject that should be aired then please delete.
thanks Paul
biggriffin
You need biopsy to assess.
had a few just lately, :)
be a Dr along shortly.. ;D
Hoof'land storeman.
chrisgixer
I doubt there is anyone here who knows Paul.
Although Guffer might, thinking about it.
Try a ring back with your gp as well. :)
I think they can get an indication from an MRI or PET scan, but I think the only sure way is by surgical removal and analysis.  :-\
Note though that I'm not a Dr...............   Unlike many!  ::)
for exact results biopsy. not googled
biggriffin
Quote from: Sir Tigger on 10 June 2014, 21:24:17
mri with contrast highlights the areas, a biopsy is a definitely way.
Hoof'land storeman.
biggriffin
Quote from: cem on 10 June 2014, 21:25:52
what i said, i don't need google..got the t-shirt. 2 kidney and 2 lymph nodes. :y
Hoof'land storeman.
D
Quote from: pauls on 10 June 2014, 21:17:21
No. A PET CT may give you a very good idea, but the gold standard test is a biopsy, either surgical or guided by a CT scan.
