Author Topic: cutting out..  (Read 1371 times)
pauls
  • By the sea minehead
    • Bmw x3
cutting out..
« on: 13 June 2014, 13:28:38 »
Wifes car nissan tino 1.8 petrol. Started and ran fine this morning.About 10mins ago start it first time for a couple of mins then stalled. Has now do it three times. No warning lights.
Any ideas if what iam looking for
Re: cutting out..
« Reply #1 on: 13 June 2014, 15:44:19 »
Could be an issue with the fuel pipe or fuel pump. The pipe can come loose on the section that connects to the engine, allowing air in which results in starting problems.
And there was a recall on the starting problems ...
A concern has been identified with the engine angle and position sensors of the engine management system, If ignored, it could cause the engine to stall and/or make it not possible to restart
« Last Edit: 13 June 2014, 15:52:11 by Emd »
pauls
    • Bmw x3
Re: cutting out..
« Reply #2 on: 13 June 2014, 17:37:23 »
I have checked all fuel pipes I was thinging it was the fuel relay. I have spoke to nissan and all he could tell me was it was in the inside of the car and it was blue. The trouble is I have two blue ones in there and i am not sure what will happen if i swap them around.
pauls
    • Bmw x3
Re: cutting out..
« Reply #3 on: 14 June 2014, 19:25:43 »
Update on this one.. It turn out to be the crank sensor Job done :y
