Author Topic: timing belt pulleys  (Read 1183 times)
idc62
  • Llanharry south wales
    • x reg 2ltr gls and 03 2.6
timing belt pulleys
« on: 16 June 2014, 21:28:21 »
Hi guys I have been gaining knowledge of my 03 2.6 mig and am quite worried after seeing pics of belt set up!!!!!. I noticed that the small pulley just above crank shaft has a offset pivot for adjusting.well I had my cover off the other day and that pully on mine is fixed it has not got the large nut around the fixing bolt is this wrong???  Hope a few of you miggy guru's can put my mind at rest cheers ian
Re: timing belt pulleys
« Reply #1 on: 16 June 2014, 21:37:25 »
Your 2.6 (and 3.2) only have one adjuster. The pictures you've found are for the 2.5/30 engines  :y  :y
idc62
« Reply #2 on: 16 June 2014, 21:50:27 »
Thanks Andy b gave myself quite a scare then at least I know the right tb kit now cheers fella :y :y :y
