Author Topic: Potential Fault List  (Read 3161 times)
Anthony in Madrid
  • Valencia, Spain
  • It's there...Go get it!
    • 1994 2.5 V6 170 BHP
« on: 17 June 2014, 13:10:15 »
Hi guys,
How ya'll doing?
I'm posting today to reach out to my fellow Omega owners and you experts for some help and pointers because I want to put a list together of things that really are essential to maintain and keep your Omega happily cruising for as long as possible.
I've got this idea that I want to keep my Omega 1995 2.5 V6 (which for 20 years old is looking and generally in great condition  ::)) on the road and keep it as healthy as possible. I mean like when you see a BMW, Porsche or Merc from the 50's or 60's and it's driving in top nick and just looks beautiful. That's what I want to do with my Miggy.
If it was you, what list of things in the engine, the electrics, the braking system, suspension etc would you prioritise and focus on to watch for wear and tear or just clean up?
For example now, the car is at the shop getting the head gasket changed and I'm focusing on the making the compression of the engine and making sure the gaskets are good and replacing any old ones. I'm also going to check all the pipes next week and look for cracks and erosion.
I'm hiring a ramp for a couple of hours next week so while I'm under it what list of things do you recommend I look for and check? What should I look for at the wishbones and surrounding area. What about the around the differential? Anything to check?
Your lists of points to check would be a great help and I appreciate you taking the time out to contribute.
All the best
Anthony
Still learning...Be nice!
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Potential Fault List
« Reply #1 on: 17 June 2014, 14:04:35 »
Hi guys,
How ya'll doing?
All the best
Anthony
For starters, hope it was the Head Gasket and not an Oil Cooler Fail.  :-\
« Last Edit: 17 June 2014, 14:09:16 by zirk »
Anthony in Madrid
  • Valencia, Spain
« Reply #2 on: 17 June 2014, 14:24:51 »
Hi...It's the head gasket. The shop confirmed. But if you don't mind..Elaborate on the "Oil Cooler fail". What would that mean and what would need to be fixed if it happens? How does one find out if that's a problem?
Cheers
« Reply #3 on: 17 June 2014, 14:28:17 »
Cheers
Ha, well you see the Omega Head gasket has been mis diagnosed by a number of garages and "specialists" hence our concern  :y
Oil Cooler - This sits in then 'V', you get oil mixing in the coolant and header tank, turns to brown gunge  :)
This is often mistake for head gasket failure, as the 2.5 V6 is probably one of the strongest V6 engines HG wise  :y
« Reply #4 on: 17 June 2014, 14:54:13 »
Cheers
Are you sure ::)
Head gasket failure generally results in an external leak around the back of the 246 head. Any oil in the water is 99/100 oil cooler failure, and readily identified as a thick creamy mud :y
« Last Edit: 17 June 2014, 14:56:51 by Taxi Al »
Anthony in Madrid
  • Valencia, Spain
« Reply #5 on: 17 June 2014, 15:16:55 »
Cheers
Are you sure ::)
Question  ::)..When the oil cooler goes is it indicated by the engine light on the dash? Also...Where is it?
« Reply #6 on: 17 June 2014, 15:17:47 »
No but then neither is the head gasket  ;D :y
Oil cooler indication is via goo in the header tank
Anthony in Madrid
  • Valencia, Spain
« Reply #7 on: 17 June 2014, 15:32:38 »
Does anyone have a pic of an "Oil Cooler"? Are they expensive to replace?
« Reply #8 on: 17 June 2014, 15:34:25 »
Depends, DIY or garage job?
Anthony in Madrid
  • Valencia, Spain
« Reply #9 on: 17 June 2014, 16:08:20 »
That's bloody awesome mister...Thanks a lot!
Anthony in Madrid
  • Valencia, Spain
« Reply #10 on: 17 June 2014, 16:12:24 »
Hi guys,
How ya'll doing?
All the best
Anthony
So..about that list? (I think this post went of track a bit lol  ;D)
But loving the comments!
And to add the longer I read all the stuff in this here forum  I'm learning tons of stuff  :y but it's a little scary as the migs seem to have a huge list of problems to watch out for  :-[ scary!
zirk
  • Epping Forest
« Reply #11 on: 17 June 2014, 16:21:08 »
You may wish to confirm your 'Head Gasket' vs 'Oil Cooler' issue, before you get a heavy Bill from the Garage.  :-\
Theres a Flow Chart Guide in FAQ's
zirk
  • Epping Forest
« Reply #12 on: 17 June 2014, 16:27:19 »
Spend some time looking though FAQ's and Maintenance Guides, and picking out various help topics.
The Omega V6 Engines are pretty robust and good for high mileage, if maintained well and Serviced properly.  ;)
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #13 on: 17 June 2014, 18:59:17 »
Nice pics tunnie  :y
Anthony in Madrid
  • Valencia, Spain
« Reply #14 on: 26 June 2014, 01:04:01 »
Just a quick question...
If I go for this job myself are replacement gaskets needed?
Cheers
Ant  :y
