Some bits for sale - mostly V6
Started by jonny2112, 19 June 2014, 23:33:48
jonny2112
With the decision to sell the Elite, I now have the following parts up for sale.
Prices don't include postage, and I will update as I go along.
New parts -
Aircon condenser (still in box, unopened) £90
Front brake pads £25
Contitech timing belt kit £125
Stag 300 LPG kit front end: loom, reducer and elbow, ECU £250
Plumbed inlet and plenum (vac, injectors and nozzles) £50 (too heavy to post maybe so could remove injectors and pipework, though you would then need nozzles and 'tapping' of inlet)
Crank sensor £30
Thermostat £20
Oil filter, element type £3
Eicher front brake discs £30
Droplinks and tie rods (unbranded) £35
Used -
Debadged grillle £25
Irmscher silhouette badge for the above (not fitted) £10
MAF £12
HBV £15
Sunroof motor £12
135 coil pack £25
Handbook and wallet £5
Boot carpet £15
First aid cover/door £10
Jack area cover £10
Headlight switch £12
There may be more. Further info and pics on request. Always open to offers.
As stated on the car for sale thread, I may be bringing the car across the water anyway, so could bring the larger/heavier items over to the NW for collection?
Thanks  :y
jonny2112
Quote from: jonny2112 on 19 June 2014, 23:33:48
New parts -
Plumbed inlet and plenum (vac, injectors and nozzles) £50 (too heavy to post maybe so could remove injectors and pipework, though you would then need nozzles and 'tapping' of inlet)  Sorry, USED parts
Crank sensor £30
Thermostat £20
Used -
MAF £12
HBV £15
Sunroof motor £12
135 coil pack £25
Boot carpet £15
Jack area cover £10
Thanks  :y
jonny2112
80 litre lpg tank probably available too
jonny2112
Revised prices -
Aircon condenser (still in box, unopened) £80
Front brake pads £20
Contitech timing belt kit £100
Crank sensor £25
Thermostat £15
Eicher front brake discs £5
Droplinks and tie rods (unbranded) £30
Debadged grillle £25 - reserved
Irmscher silhouette badge for the above (not fitted) £10 - reserved
MAF £12
HBV £12
Sunroof motor £10
135 coil pack £25
Boot carpet £15
First aid cover/door £8
Jack area cover £8
Headlight switch £10
Lpg tank 80l £50
OE Omega carpet mats – slight wear to driver's (will add photo) £30
jonny2112
Quote from: jonny2112 on 20 June 2014, 20:54:28
Revised prices -
Stag 300 LPG kit front end: loom, reducer and elbow, ECU £250 - reserved
Plumbed inlet and plenum (vac, injectors and nozzles) £50 (too heavy to post maybe so could remove injectors and pipework, though you would then need nozzles and 'tapping' of inlet)  - reserved
Crank sensor £25
Thermostat £15
MAF £12
HBV £12
Sunroof motor £10
135 coil pack £25
Boot carpet £15
Jack area cover £8
Lpg tank 80l £50 - reserved
jonny2112
Revised prices -
Stag 300 LPG kit front end: loom, reducer and elbow, ECU £250 - provisionally sold
Plumbed inlet and plenum (vac, injectors and nozzles) £50 (too heavy to post maybe so could remove injectors and pipework, though you would then need nozzles and 'tapping' of inlet)  - provisionally sold
Crank sensor £25
Thermostat £15
Debadged grillle £25 - provisionally sold
Irmscher silhouette badge for the above (not fitted) £10 - provisionally sold
MAF £12
HBV £12
Sunroof motor £10
135 coil pack £25
Boot carpet £15
Jack area cover £8
Lpg tank 80l £50 - provisionally sold
jonny2112
Quote from: jonny2112 on 20 June 2014, 23:15:40
Revised prices -
Crank sensor £25
Thermostat £15
Debadged grillle £25 - sold
Irmscher silhouette badge for the above (not fitted) £10 - sold
MAF £12
HBV £12
Sunroof motor £10
135 coil pack £25
Boot carpet £15
Jack area cover £8
jonny2112
Quote from: jonny2112 on 20 June 2014, 23:40:25
Revised prices -
Crank sensor £25
Thermostat £15
Eicher front brake discs £15
MAF £12
HBV £12
Sunroof motor £10
135 coil pack £25
Boot carpet £15
Jack area cover £8
jonny2112
Revised prices -
Aircon condenser (still in box, unopened) £70
Contitech timing belt kit £80
Crank sensor £25
Thermostat £10
Droplinks and tie rods (unbranded) £25
Used parts-
MAF £10
HBV £10
Sunroof motor £10
135 coil pack £20
Boot carpet £15
Jack area cover £8
jonny2112
I also have a scuttle panel and a V6 throttle body  :y
jonny2112
Update -
Aircon condenser (still in box, unopened) £70 - no longer for sale
Front genuine brake pads £20
Contitech timing belt kit £80 - provisionally sold
Crank sensor £25
Thermostat £10
Used parts-
MAF £10
HBV £10
Sunroof motor £10
135 coil pack £20
Boot carpet £15
Jack area cover £8
Scuttle panel £10
V6 throttle bodies £10
Cabin filter (carbon) £10
Open to offers on everything.
Thanks.
steve6367
Quote from: jonny2112 on 27 June 2014, 01:06:32
Update -
Crank sensor £25
Thermostat £10
Used parts-
MAF £10
HBV £10
Sunroof motor £10
135 coil pack £20
Boot carpet £15
Jack area cover £8
Scuttle panel £10
Thanks.
Is that GM?
jonny2112
Mmm. Good question actually  ???
I bought it a while ago as a spare, as 'new old stock'.
I would need to check though. Are there specific markings on the casting to confirm?
steve6367
I think it should have GM and a part number stamped on it.
Steve
jonny2112
Quote from: steve6367 on 28 June 2014, 23:30:16
Steve
Apparently not  >:(
Gutted! One for the skip then
