Author Topic: Door handle not working  (Read 1549 times)
wiliferus
  • Reading
    • 2003 2.6 CDX Saloon Auto
« on: 24 June 2014, 19:47:51 »
Has anyone got a fix for a drivers door outside handle stopped working.
Admittedly it's been one of those niggly things I've been meaning to look at - for ages it didn't open until right at the end of the movement of the handle and I knew it was on its way out. Tonight it's stopped working all together.
It's a 52 plated saloon.
Is it a reasonably quick fix with something that needs clipping back on, or is it more likely to be something broken?
Thanks in advance.
wiliferus
  • Reading
Re: Door handle not working
« Reply #1 on: 24 June 2014, 19:55:24 »
I should add, it opens fine from inside, so happy the lock itself is fine, it something to do with the exterior handle connection/mechanism.
« Reply #2 on: 24 June 2014, 20:15:32 »
Remove door card. Attached to the handle is an actuating rod that sits in the "knuckle" arrowed red. Make sure it`s in secure
wiliferus
  • Reading
« Reply #3 on: 24 June 2014, 21:23:07 »
That's brilliant, thank you. WD40 squirted through from outside seems to have sorted it for now back to its previous working right at the end of its travel.
I didn't have time to mess around taking the door card off tonight, but will have to take the plunge in the weekend.
symes
  • oxford
    • R reg 940 volvo
« Reply #4 on: 24 June 2014, 22:47:53 »
the rod on handle is probably bent-causing it to only work at last bit :y
