Author Topic: Help - indicators, or lack of  (Read 5246 times)
Re: Help - indicators, or lack of
« Reply #15 on: 26 June 2014, 17:53:14 »
Changing the flasher changed the symptom. That makes me suspicious of the part.
I think I'd be getting the meter out about now...
« Reply #16 on: 26 June 2014, 18:23:06 »
Funny you should say that Jaime but I have a nagging gut instinct re the replacement flasher relay :-\  Already made arrangements to obtain another tomorrow - will see then if my instinct is right (or wrong!).
« Reply #17 on: 27 June 2014, 15:36:18 »
Final update - replaced the large flasher relay in the fuse box with another (thanks gain to Serek :y), and indicators and hazards now working normally.  Should have stuck to original gut instinct and saved me swapping hazard switch (pita to get out), swapping the grey relay behind glove box (more work dropping glove box out), and swapping indicator switch.
Thanks to all for suggestions :y
« Reply #18 on: 27 June 2014, 17:51:38 »
Sorted :y
« Reply #19 on: 27 June 2014, 21:30:56 »
