Author Topic: ATF Leak  (Read 1945 times)
ATF Leak
« on: 24 June 2014, 22:31:07 »
I have one.  :(  Any favourite places to start looking?  :-\
The leak seems to be coming down the back in that favourite place for all leaks.  :(  and it all looks OK at the rad end and the flexi pipes!  ;)
TIA!  :)
Re: ATF Leak
« Reply #1 on: 25 June 2014, 01:53:01 »
Pull the rubber plug off at base of bell housing and feel with your finger inside bell housing.  If wet with atf you have a leak on gearbox shaft seal - cheap and easy to fix, but you do have to drop the autobox out :(  Ideally need help plus a good trolley jack (car on ramps helps) - talking from experience it a heavy old lump, but easy enough to drop out, and refit.
Re: ATF Leak
« Reply #2 on: 25 June 2014, 09:42:30 »
Thanks dbug!  :y
Sounds like the ideal 'opportunity' to take the sumps off and change the ATF and filters etc!  :y
Can't wait!!  ::)  ;D
Temetsy
  • Finland
    • b1 x25xe sedan
Re: ATF Leak
« Reply #3 on: 26 June 2014, 11:23:17 »
Change the o-ring on the tip of the shaft too! Had to do the sealing job twice because missed that little c*nt! :D
Re: ATF Leak
« Reply #4 on: 26 June 2014, 11:43:14 »
No offence intended but the c word is possibly a bit too naughty on this forum :y
Tigger how much are you losing?
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: ATF Leak
« Reply #5 on: 26 June 2014, 12:15:06 »
Thanks dbug!  :y
Can't wait!!  ::)  ;D
its not that bad, just use a washing up bowl, one sump at a time, and then refill using a fence sprayer thingy.. :)
and you can re-use the filter,just wash it in petrol.
Hoof'land storeman.
Re: ATF Leak
« Reply #6 on: 26 June 2014, 20:46:34 »
Not much James, it's just drips but I'm not sure how long it's been like it to be honest.  :-\
I've been thinking about changing the ATF for a while now so I'll just have to get stuck in soonish I think!  ::)
Temetsy
  • Finland
    • b1 x25xe sedan
Re: ATF Leak
« Reply #7 on: 29 June 2014, 22:50:23 »
That's why I censored it  ::)  thb sorry for that, just gotten used to use maybe a bit too rough language  :-X  Still though, CHANGE THAT O-RING!  :y
