Author Topic: Coolant Flush Questions  (Read 1225 times)
Anthony in Madrid
  • Valencia, Spain
  • It's there...Go get it!
    • 1994 2.5 V6 170 BHP
« on: 25 June 2014, 15:55:42 »
Hola guys!  :y
OK the questions are coming thick and fast now as I TLC my Miggy Queen to the Max... ::)
If there is an coolant flush on the cards...(Mine for sure as it's almost like cloudy coffee! :-[) Then I've read a few posts about the fact that the new flush water doesn't go around the whole engine and heater matrix if the Thermostat is closed. So ...Heres my questions:
1. Open/Close thermostat? Does that mean remove it when flushing or is there a switch or something that does the job.
1a. If the thermostat is removed/closed then will the flush go to the heater matrix too?
2. I'm not near a hose pipe so can this be done manually through bottles of water?
3 Which is the best maintenence guide to follow for the flush here on the forum?
Cheers everyone  :y
Anthony
Still learning...Be nice!
kevinp58
  • kent
    • 2002 3.2 elite
Re: Coolant Flush Questions
« Reply #1 on: 25 June 2014, 16:22:21 »
Hola guys!  :y
Cheers everyone  :y
Anthony
Have you checked your oil cooler is ok as this is a sign that it may be on its way, or it could be that the coolant has never been changed  :-\
There is a make called forte that is very good at cleaning :y
1a the water will go in the matrix if the heat is set to max and eventually the stat will open so it will go right round the engine too :y
« Last Edit: 25 June 2014, 16:25:02 by kevinp58 »
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #2 on: 25 June 2014, 16:45:22 »
Take it this is the same car that the Garage said you had a Head Gasket fail?
Did you check the Oil Cooler as suggested last week?, if your cooler has gone doing a flush is a bit pointless until its fixed.
Anthony in Madrid
  • Valencia, Spain
« Reply #3 on: 25 June 2014, 17:23:50 »
Hi..Yes  :y It's the same car.
Cheers
Ant
