Author Topic: Electrolysis for rust removal....  (Read 2262 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 25 June 2014, 21:31:56 »
.....talk to me.
Just read about this. Has anyone used this method? From what I've read it is the best way to remove rust other than cutting it out/welding new in.
Any info/experience anyone???
RIP Paul Lovejoy
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
Re: Electrolysis for rust removal....
« Reply #1 on: 25 June 2014, 21:59:53 »
I taught electronics, not mechanics, but my mechanical colleagues used a thing called a Spark Eroder to free corroded parts. I expect you already know what it does, but just in case; it applies a high voltage at a distance from the corroded part and a spark jumps from the Eroder to the part, etching the crud away.
I don't suppose that technique could be used on a car, but I thought it was worth a mention.
Ron.
« Reply #2 on: 25 June 2014, 22:02:06 »
Read up on it here ..
http://www.stovebolt.com/techtips/rust/electrolytic_derusting.htm
or here .. just the same chemistry with different ideas/techniques
http://antique-engines.com/electrol.asp
« Last Edit: 25 June 2014, 22:08:22 by Entwood »
Webby the Bear
  • Northampton
« Reply #3 on: 25 June 2014, 22:03:12 »
Thanks BR,
I've literally no knowledge on this other than I've just read about it... some dude chucks a properly rusty back plate/hub assembly in a ''bath'' and next morning its like brand new  ??? ??? ??? ??? ???
presumably this cant be rigged to do a chassis/body sections?
RIP Paul Lovejoy
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #4 on: 25 June 2014, 22:03:22 »
How are you going to manage it on the car?
Once bodywork corrodes, cutting and welding is the only answer.
Webby the Bear
  • Northampton
« Reply #5 on: 25 June 2014, 22:05:59 »
That's what I was thinking....but worth a ponder imo
RIP Paul Lovejoy
« Reply #6 on: 25 June 2014, 22:16:32 »
high voltage sparks on a car :-\
you may end up with a burned ecu only if you are lucky.. dont want to mention mention bad luck options ;D
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #7 on: 25 June 2014, 22:16:59 »
Tried it on my hubs does work but takes ages and it stinks. Use a media blasting cabinet and get the same results in less time.
Webby the Bear
  • Northampton
« Reply #8 on: 25 June 2014, 22:19:02 »
Just got a bit excited, Cem... when I saw ''removes all rust and is very cheap'' my eyes lit up  ::)
Had visions of the car sitting in a paddling pool while I drink beer and put no effort in at all... you get the picture  ;D
RIP Paul Lovejoy
« Reply #9 on: 25 June 2014, 22:53:00 »
Electrolysis - thought that was for hair removal ;D ;D ;D
« Reply #10 on: 25 June 2014, 23:20:54 »
Individual parts it does work , when are we stripping your car down to the chassis  ::) ;D
Webby the Bear
  • Northampton
« Reply #11 on: 26 June 2014, 07:51:34 »
Next meet at Symes'  ;D ;D ;D ;D
RIP Paul Lovejoy
« Reply #12 on: 26 June 2014, 12:15:37 »
Webby, have a butchers here...
http://www.farrowsystemsuk.co.uk/
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #13 on: 26 June 2014, 12:23:30 »
 use to acid dip shells for motorsport, that removes everything,and lightens them  :)
Hoof'land storeman.
