Author Topic: Omega A C30NE spark plugs  (Read 1508 times)
R-vin
  • Trinidad, W.I.
  • Best Regards
« on: 26 June 2014, 03:13:28 »
hi,
does any one know what spark plugs can be used on the Omega A C30NE  engine, it runs only on gasoline,  the owners manual specifies BPR6HS spark plugs, but these are hard to find....
R-vin
Keith ABS
  • Maldon Essex
Re: Omega A C30NE spark plugs
« Reply #1 on: 26 June 2014, 07:46:29 »
Is it a12 valve or 24 valve engine?
Keith B
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 26 June 2014, 12:26:32 »
Think 3.0ne is 12v and 3.0se is 24v.
Hoof'land storeman.
LC0112G
« Reply #3 on: 26 June 2014, 13:57:04 »
EPC lists (ACDelco) CR42CFS, which superceeds to (Bosch) WR7BC. Vx number is 90297143, opel is 12-14-805.
Also used on some Corsa A's,
Keith ABS
  • Maldon Essex
« Reply #4 on: 26 June 2014, 19:38:18 »
  I have GM ones here for both engines but the cost of shipping out to you will probably be to expensive
Keith B
R-vin
  • Trinidad, W.I.
  • Best Regards
« Reply #5 on: 30 June 2014, 02:29:16 »
hey guys,
 thanks for the info...i`m currently hold up in Brazil.... no Omega B`s here, only Omega A`s (93-98) after which the rebadged LHD commodore was imported fully assembled....  i found the 3.0 6cyl estate Omega A with the C30NE 12v engine / auto tranny at what i thought was a bargain, now i realise why it was being sold, Brazil never had a good parts back up / spare parts.....
 93214694 is listed online as a AC Delco substitute,the brasilian manual states BPR6HS as the spark plug,  cross referencing here reveals that this plug does not have a substitute...   i remember that NGK had a naming scheme such as BP5ES for a hot plug and the BP6ES for the colder plug....  does this apply to NGK plugs across the board??????
if the BPR6HS referrs to a colder plug, would BPR5HS be the hotter plug version?
i`ve come across BPR6EY readily available here in brazil..... but can`t find any specs / dimensions online....
what can be consequences of using a hotter plug than the colder one?  will it increase the instance of pre ignition as i frequently hear from cars climbing the  steep hill where i stay at?  what about gas mileage? would i consume more using a hotter plug?
warm regards
R-vin
R-vin
Page created in 0.008 seconds with 16 queries.
