Pages: [1] 2 3 4 5 6   Go Down
Author Topic: CPS Symptoms of Failure  (Read 19809 times)
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
« on: 27 June 2014, 10:16:51 »
Can anyone tell me the above?
Having serious issues with my 3.2 and this misfire I'm having, when it happens it's like having the brakes slammed on!! It literally throws you forward! I have to come off the gas, dip the clutch and start as per normal.
Happens with no real pattern either, very irregular!
Help!!
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: CPS Symptoms of Failure
« Reply #1 on: 27 June 2014, 10:30:04 »
Help!!
Crank Sensor (if thats what your referring to) is normally a no start problem, or  Ive heard in some cases, Engine cut out, followed by no start. As for the slamming you foward bit, no idea, does the TC or ABS light flash up at all?
zirk
  • Epping Forest
« Reply #2 on: 27 June 2014, 10:32:21 »
As usual, any Codes?
P6UL K
  • Dartford, Kent
« Reply #3 on: 27 June 2014, 10:56:27 »
Nope there's no codes and no fault lights either, I've had all the issues resolved that made the dash like a Xmas tree!
« Reply #4 on: 27 June 2014, 11:01:44 »
ignition related..  which the ecu cant resolve..
P6UL K
  • Dartford, Kent
« Reply #5 on: 27 June 2014, 11:17:08 »
Any thoughts then Cem?
« Reply #6 on: 27 June 2014, 11:28:15 »
When was the fuel filter last changed :-\
What mods have you made to the fuel/air delivery sides?
« Reply #7 on: 27 June 2014, 11:29:14 »
A 3.2 ECU is intelligent enough to create cylinder misfire codes if ignition problems cause a misfire, unlike the 2.5/3.0. :-\
zirk
  • Epping Forest
« Reply #8 on: 27 June 2014, 11:50:38 »
Hmm, must admit any DBW potential Miss Fires even small hic up ones have always thrown a fault light, be it only briefly sometimes. when was the last time the Codes were read with a Reader?
P6UL K
  • Dartford, Kent
« Reply #9 on: 27 June 2014, 11:51:44 »
Fuel filter was done within the last year.
Only mods are the air box and K&N filter, has had new Vx coilpacks, plugs, oil and filter in the last 3 months
« Reply #10 on: 27 June 2014, 11:52:11 »
Which is why I didn't say loom, as that definitely generates codes...
Another thought, is the fuel light on/less than 1/4 tank :-\ what speed are you doing when this happens? Accelerating?
Top of the red to run out is about 5 miles at full chat :-X and fuel starvation is about the only thing which won't put a light on...
P6UL K
  • Dartford, Kent
« Reply #11 on: 27 June 2014, 11:53:41 »
Quite a while ago Chris, bloody typical this is as I'm driving to Devon on Monday for family hols! >:(
P6UL K
  • Dartford, Kent
« Reply #12 on: 27 June 2014, 11:58:37 »
Fuel very rarely goes below 1/4 of a tank and I always try to use Shell or Esso fuels if I can.
Yes always happens under acceleration albeit light or heavy footed, I did wonder if the signal from the pedal is breaking up on route to the ECU?
zirk
  • Epping Forest
« Reply #13 on: 27 June 2014, 12:16:21 »
Is it Oil'ed, Maf needs cleaning?  :-\
P6UL K
  • Dartford, Kent
« Reply #14 on: 27 June 2014, 12:28:04 »
It's brand new mate, came oiled up already. I cleaned the MAF before fitting the filter but could there be a chance that the MAF is on it's way out?
Pages: [1] 2 3 4 5 6   Go Up
