Author Topic: HELP! Oil pressure disapeard problems  (Read 1029 times)
Dreamez
  • Finland
    • Opel Omega MV6
« on: 27 June 2014, 21:50:54 »
I bought a Opel Omega mv6 3.0 liters y:97 as a damaged, defect reported tapping machine - the former owner of the car started to demolish (removed automatic gearbox etc), further action was necessary to have a smoke from the machine in order to be heard on whether the clack clack or clatter of.
Today we got the machine running with just the exhaust manifolds - no tubes, no other symptoms at the time of the engine failure light / what little gunfire heard from
no alarming noises - we continued and putted front tube (cats in) in their places, now the oil pressure light has turned on completely clear all the time to sound the bottom
bearing a heavy dragging sound, and covers of the missing pressure causes a chattering sound on both sides of the lifter.
The machine previous owner over the black-oil-term (over the top mark) - changed the functioning of the engine oil pressure sensor - still lights up
all the time / cable disconnection switch off the light so that the wire is not on the body.
I think that when i started the car for first time, that light wasn´t on (about 30-40 seconds) even though the attention of all the other little exporting to.
Now it seems like that the sensor does not detect the pressure on (the light is, therefore, all the time) But are there now, pump Dead whether or sufficiency of one of the bearings
or any overpressure valve surrender to that light, what do these V engines usually are caused by pressure loss / idle: usually a
starts to blink and turn off the rounds yet, but this was quite high RPM idle (more than 1200r/min).
I personally do not believe any of the oil filter clogging / time is unlikely, I also pump a duct clogging, modern oils.
What the jury to guess what could those symptoms have agreed to these diagnos / I doubt the cost of effort to perform Forte, etc flush and new oil and filter
current account is likely to further increase the amount of damage, what should be first checked - the channel to attach the oil pressure gauge, and we do not have the former owner
Explanation (a young fellow who is not knowledge of cars) do not provide any additional information.
« Last Edit: 27 June 2014, 21:58:02 by Dreamez »
Dreamez
  • Finland
    • Opel Omega MV6
Re: HELP! Oil pressure disapeard problems
« Reply #1 on: 27 June 2014, 22:14:40 »
the car havent been running in 2 years.If it helps?
Omegatoy
  • UK
« Reply #2 on: 28 June 2014, 09:00:08 »
souns like the pick up pipe is clogged through lack of correct interval oil changes,an unfortunate all to common occurence even with modrn oils,
jm2pw
