Author Topic: washer bottle/pump part No. ?  (Read 4419 times)
powerslinky
« on: 29 June 2014, 16:09:35 »
hi all ,
          got a leak from the washer bottle behind the bumper  ('53 3.2 elite)
Now bumper & bumper bar are off , I can see it is leaking from around the rubber grommet/seal between the pump & the bottle.
The pump itself does not seem to be a firm fit in the "push in" clamp moulded into the bottle or indeed into the rubber grommet/seal.
 The pump looks fairly new , so wondering if it is the wrong one  :-\
part no. on the pump is GM 90 508 707     with Textron 19222 written below that .
can anyone look up the correct part No.   and see  these numbers correspond to the pump that should be fitted .
If so & pump is correct  one ,  it must be the grommet/seal worn  ::)   . .  or wrong rubber seal :D :D
TIA    Al :y
« Last Edit: 29 June 2014, 16:11:50 by Essex Big Al »
Re: washer bottle/pump part No. ?
« Reply #1 on: 29 June 2014, 16:46:44 »
Windscreen or headlight pump :-\
powerslinky
« Reply #2 on: 29 June 2014, 17:04:59 »
[/highlight]
hang on  . . . i'll go and hav a look  :-[ :-[ :-[
Headlight washer Rob  :y
« Last Edit: 29 June 2014, 17:06:35 by Essex Big Al »
« Reply #3 on: 29 June 2014, 17:15:43 »
90508709 on the facelift
powerslinky
« Reply #4 on: 29 June 2014, 17:35:41 »
My mistake Rob . . . :-[ :-[ :-[   just checked & that is what is fitted  90508709 ( I gave wrong No. in original post  :-[)
The pump seems very slack when clipped into position & easily slides up & down . If you gently push downwards on it  . .
the leak stops  . .  as you release the pump rises up slightly & leaks starts again .
it seems pump body is too slim  or the rubber seal/grommet is not tight enough.
Could you possibly find  a part No.  for the grommet ?
« Reply #5 on: 29 June 2014, 17:40:24 »
Grommet incorporates the filter # 90347698
« Reply #6 on: 29 June 2014, 17:45:01 »
Ignore that Al, that`s for the windscreen pump. I`ll try and find # for what you need
« Reply #7 on: 29 June 2014, 17:47:40 »
Here you go Al. # 90053056 Although a rubber grommet, it`s referred to as the pump to reservoir gasket ???
powerslinky
« Reply #8 on: 29 June 2014, 17:48:20 »
Got a picture Rob ?  as can't see a filter .  Pump pulls out & leaves the black rubber "grommet" in situ. This pulls out from the Bottle/tank  but is just a round rubber grommet. it does have a raised ring which looks like it could be the "seal" to the bottle.
Leak is occuring between  top of grommet & the pump body . Possibly something missing her I think  :-\
EDIT:  just seen your last post  . .  but a pic would still be helpful  ;)
« Reply #9 on: 29 June 2014, 17:50:09 »
Give me 5 minutes
powerslinky
« Reply #10 on: 29 June 2014, 17:54:30 »
Give me 5 minutes[/highlight]
long as you need mate  . . . cheers  :y
« Reply #11 on: 29 June 2014, 17:59:30 »
Pump with attached grommet
Stand alone pics of grommet
powerslinky
« Reply #12 on: 29 June 2014, 18:03:56 »
thanks Rob .
                 looks exactly what is fitted here.  Pump & grommet.   I'll try a new grommet first as the pump pulls easily out of the grommet .
Thanks again for the help & the pics .  :y :y
« Reply #13 on: 29 June 2014, 18:05:07 »
No probs :)
« Reply #14 on: 29 June 2014, 19:19:46 »
Could try three turns of tape around the pump body between the seal and the first clip on the bottle...
