Pages: [1] 2 3  All   Go Down
Author Topic: Coolant Mayo and losing oil  (Read 5643 times)
Hmouse
« on: 01 July 2014, 18:49:45 »
Hi Folks,
I'm Andy and I have just bought an Omega 2.6 CD.... nice smooth vehicle. Just developed a problem, coolant turned to mayo and under pressure, plus losing oil. After reading the forum I and hoping its just the oil cooler and not the Head gasket...fingers crossed. Dropping it off at the garage tomorrow.. A really nice car to drive and I am hoping for a long and happy ownership.
  H
flyer 0712
Re: Coolant Mayo and losing oil
« Reply #1 on: 01 July 2014, 18:51:29 »
Sounds like cooler..good luck at the garage..
« Reply #2 on: 01 July 2014, 18:53:08 »
Oil Cooler failure, don't let them tell you it's head gasket, because it's not  :y
See what they quote, but a few members here offer mobile mechanic work at a vastly cheaper cost I bet  :y Also be done right :)
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #3 on: 01 July 2014, 18:54:14 »
they will no doubt tell you its head gasket though...
sounds like oil cooler to me.  :y
Hmouse
« Reply #4 on: 01 July 2014, 18:58:21 »
Thanks Guys, I had done a bit of reading and you have confirmed my hopes.. Let you know how it goes. H
chrisgixer
« Reply #5 on: 01 July 2014, 19:32:30 »
I hope you didn't tell them your suspicions. I bet they say head gasket. ;D
It is oil cooler btw. There's no other way oil can get in the cooling system.
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #6 on: 01 July 2014, 21:00:23 »
Hi Folks,
  H
Should be a shitty brown and as others have said more than likely the cooler, they are easy to do there are threads here to show how to do it :y :y
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
« Reply #7 on: 01 July 2014, 21:28:11 »
It will be interesting what kind of money they want for the repair ::) As already said i would ask a member on here for quote :y
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
allen25
  • Worcestershire
    • Omega 2.6 V6 2001
« Reply #8 on: 02 July 2014, 02:36:45 »
I had the same symptoms as you, it was the oil cooler on mine.
Regarding the oil loss, is this related to the cooler failure forcing oil/brownish sludge out of the coolant header tank or is it 'dripping' elsewhere? The reason for asking is that cam cover seals tend to fail on the V6 over time. There is plenty of info on here relating to that.
Also on the very early 2.6 there was a known issue with valve oil seals from memory. I had this problem personally. With this issue you typically don't see oil loss dripping from the engine, the oil is consumed/burnt by the engine and you have to top up regularly. Most would probably have been repaired to cure the problem but it is possible that some were not and were simply topped up with oil as necessary.
All food for thought but personally I would start by checking the cooler.
Hmouse
« Reply #9 on: 03 July 2014, 14:57:03 »
Hi Guys,
Update time.....
First reaction from the garage was "probably the Head Gasket Mate"!
I explained to them that the OOF were positive it would be the Oil cooler. Well a couple of hours after leaving the car at the garage I received a call.... Yep Oil cooler... on order and car will be back on the road by Monday. They will flush the coolant out and fit said cooler....price ah well....its £540 all in.. I have gone ahead with it (mainly they are our local garage and not let us down in the past). Thanks for all your help guys, nice to be made welcome.
« Reply #10 on: 03 July 2014, 15:09:22 »
Hi Guys,
Update time.....
That is crazy money. I paid £220 plus a bottle of Glenlivet. That included new oil and filter plus 5 litres of red GM coolant. :y
Wishing you well though. :y
« Reply #11 on: 03 July 2014, 15:23:06 »
Hi Guys,
Update time.....
 :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o
Can you get a break down on that?
« Reply #12 on: 03 July 2014, 15:27:48 »
Hi Guys,
Update time.....
........and is that with genuine GM parts?
chrisgixer
« Reply #13 on: 03 July 2014, 15:30:35 »
Opps me. And to think I/we did Arrons for curry ;D
« Reply #14 on: 03 July 2014, 16:03:56 »
Hi Guys,
Update time.....
I did it much to cheaply!  :D :D :D :D :D ;D :y
Pages: [1] 2 3  All   Go Up
