Plasma cutter recommendation
Started by chrisgixer, 02 July 2014, 01:25:27
Quote from: tunnie on 02 July 2014, 17:11:09
Can I have a go if you get one, they look like fun  :D
They are by far the easiest way to set light to the sound deadening foam in the back of an old Jag..
Don't ask how I know.. ;D I blame Stuart..
Quote from: aaronjb on 03 July 2014, 10:25:07
Ahh, yes. The "XJ12 compact". :D
Or.. "Ways to risk destroying your garage Number.." well, One's clearly taken already so.. "2." ::)
 ;D ;D Yes, next I'll try seeing if I can set light to things with my new welder ;)
Definitely the quickest way to dismantle a car short of a gas axe, though!
r1
Quote from: Marks DTM Calib on 03 July 2014, 08:24:10
Quote from: r1 on 03 July 2014, 07:49:50
I just want to use one to see how I get on with it.
Come and have a go with my plasma cutter if you want
might take you up on that
give me a shout when you doing something with it.
Quote from: aaronjb on 03 July 2014, 10:44:52
They're not as good for that as you think. Performance drop once you try cutting double-skinned panels, or flanges.
The best thing for cutting up a car is a big disc cutter, which will rip through all the awkward areas in no time. I used to be able to cut a stripped Capri into manageable chunks in 15 minutes.
biggriffin
Quote from: Nick W on 03 July 2014, 17:39:14
tooltime voice. Rrrr big disc cutter, petrol powered,. 2nd the above ::)  :y
Hoof'land storeman.
chrisgixer
Arrived today. Disc cutter of no use what so ever for what I needed it for ::)
Nice one Mark, thankyou. :y
Have fun and remember to make sure you connect the ground connection before you pull the trigger or the pilot arc can give you a bit of a belt  ;D :D
Gaffers
Quote from: Marks DTM Calib on 17 July 2014, 08:13:23
I take it there is some precedence to that remark ::) ;D
chrisgixer
Indeed, how does Master know this ;D ;D
Having finished with the plasma cutter. There was a milisecnd where I wondered why the welder wasn't working though. Hmmm, that ground clamp looks quite new "Wrong ground clamp you twonk" ;D ;D ;D
Gaffers
chrisgixer
::) ;D
I'm using a welding mask for this. I noticed master used goggles....? :-\
Gaffers
Quote from: Monsieur Guffer on 17 July 2014, 13:58:06
;D
Suspect full mask gives better protection, whilst goggles offer greater flexibility :-\
Gaffers
You can't be a mad scientist the master wearing a full mask.  That's just creepy ;D
