Plasma cutter recommendation
Started by chrisgixer, 02 July 2014, 01:25:27
chrisgixer
Spoke to Master a while back about this and obviously he gave me all the details, good chap that he is.
...I didn't write them down though. :-[
Maybe have a look here and see what their recommendations are? http://www.mig-welding.co.uk/forum/forums/plasma-cutters.34/
Be careful on eBay - a friend of mine bought one from there and it came with a 13A plug containing a piece of steel bar as a fuse...
Just how much are you going to use it? It's been more than a year since I plugged mine in, and I've done a fair amount of metalwork since then.
Unless you already have a good welder, angle grinders, clamps and all the other bits and pieces, you could spend £400 much more usefully.
I guess it depends on your plans, mine gets used a lot  :y
chrisgixer
Quote from: Nick W on 02 July 2014, 08:34:22
That's not really the point. Its a case of what else the job is holding up. Which is far, far more important.
Not the most helpful post either Nick, given the question.
chrisgixer
omega2018
ive got a ct520 plasma cutter, welder and tig all in one.  very pleased with it slices through 15mm steel no problem which is what i bought it for. i paid £325 new  i see they are now £299 on ebay inc free angle grinder, search for ct520.  had to reconnect the internal earth lead when it arrived  - it is made in china but no probs since £299 to cut up to 18mm steel bargain
Can I have a go if you get one, they look like fun  :D
Quote from: tunnie on 02 July 2014, 17:11:09
Perfect for a 4 pot estate conversion, I'd say. :y If that doesn't go well, we'll turn it into a barbecue.  :D
Quote from: Marks DTM Calib on 02 July 2014, 08:07:49
R-Tech P30C
http://www.r-techwelding.co.uk/welding_equipment/Plasma_Cutter
Very very good and very good support
How spooky is that :o
Still, cut and paste made it easy
(for others, I PM'd MDTM pretty much an identical question last night!)
chrisgixer
Quote from: TheBoy on 02 July 2014, 19:23:29
R-Tech P30C
Ge'roff, its mine. Mine mine mine ;D
Although, do we really need two between us?
r1
I just want to use one to see how I get on with it.
Quote from: r1 on 03 July 2014, 07:49:50
Come and have a go with my plasma cutter if you want
