Author Topic: Plastic wheel arch liners vs rust  (Read 1984 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 05 July 2014, 20:10:48 »
Evening fellas...
As my topics recently have mainly been about rust I figured I could go on about rust bu....... so I will  :y
Ma's Ford Fusion. Has plastic trim around the wheel arches.
Are these a magnet for stagnant water and early rusting i.e. they keep old water locked in and make everything rusty? I note that when she reverses off our drive (which is slightly sloped) after a night of rain you see water coming out from them. Would the best solution be to whip these off and treat / underseal them to prevent rust from happening?
RIP Paul Lovejoy
4x4
Re: Plastic wheel arch liners vs rust
« Reply #1 on: 05 July 2014, 20:18:03 »
Rear arch liners will normally cause the rust ,on the puma/fiesta was a common problem,all you can do is remove,clean all the crap out,and rust treatment,when refitting maybe cut about 1-2mm off the edge where its closest to the arch  :y
« Reply #2 on: 05 July 2014, 22:10:30 »
definitely..
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #3 on: 06 July 2014, 00:01:48 »
I think the problem is the moisture traps they they can cause as they definitely stop stones etc. thrown up by the wheel, chipping the paint / underseal  and causing rust, which is what used to happen before they were fitted on cars.
1960's rust buckets without these would have major wheel arch corrosion problems in 3 to 4 years. :o :o :o
Webby the Bear
  • Northampton
« Reply #4 on: 06 July 2014, 00:03:11 »
Thanks boys. I'll whip the liners off when I get a chance and do what I can to underseal  :y
RIP Paul Lovejoy
« Reply #5 on: 06 July 2014, 09:33:25 »
As long as its been properly undersealed from factory the plastic liners will last far longer that exposed paint , as said stone chips will create rust as on most non plastic wheel arches  :y I mean look at the Ka  ::) The rear arches are good , just the rest of the car is disolving around it  ;D
