Author Topic: Handbrake cable  (Read 1991 times)
Ralph
  • Northumberland
    • 2.6 MV6
Handbrake cable
« on: 09 July 2014, 20:21:22 »
Hi,
Does anyone know the diameter of the handbrake cable where it passes through the bracket on the suspension arm.
I suspect the bracket on n/s has weakened & the cable keeps slipping through & opening  up the hole.
Thanks
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
Re: Handbrake cable
« Reply #1 on: 09 July 2014, 20:33:08 »
I'll nip out to the garage and check on the new one I have  :y
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: Handbrake cable
« Reply #2 on: 09 July 2014, 20:39:36 »
They all do that when they get old. The coiled bracket on the suspension arm get rusty and brittle and the able pulls through it. Cure is a washer on the cable.
joff
  • swindon, wilts
  • Discovery TD5 ES
Re: Handbrake cable
« Reply #3 on: 09 July 2014, 20:44:10 »
15.85mm metal collar and the cable is 3.8mm outer plastic cover is 10mm :y
Re: Handbrake cable
« Reply #4 on: 09 July 2014, 21:30:53 »
Crimp the bracket up a bit :y
Ralph
  • Northumberland
    • 2.6 MV6
Re: Handbrake cable
« Reply #5 on: 09 July 2014, 21:49:43 »
I crimped it up a week ago & it's started to pull through again already, I was planning to put a washer on the outer cable collar.
Ralph
  • Northumberland
    • 2.6 MV6
Re: Handbrake cable
« Reply #6 on: 09 July 2014, 22:05:15 »
Thanks Joff, saves crawling about the garage floor instead of watching the football.
Re: Handbrake cable
« Reply #7 on: 09 July 2014, 23:15:52 »
What football...
 ;D
