Author Topic: Air/con recharge bottles  (Read 9214 times)
Re: Air/con recharge bottles
« Reply #15 on: 18 July 2014, 16:03:26 »
Seen a seal replacement kit at Alfods , best get the valve changed and some new seals in before anything  ::)
Most AC places will check it free of charge, and will only charge you if the system is leak tight and you have functioning AC.  :y
So take it to an AC place and then you'll know if it's leaking and if so where from.  ;)
Have you pressed the valve in? Does it hiss?  ???
No hissing at all  :(
See above...
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #16 on: 18 July 2014, 16:04:10 »
Stupid question?
Is there such a thing as a RadWeld equivalent for air con systems, to plug a leak in the radiator?
Ron.
« Reply #17 on: 18 July 2014, 16:05:53 »
See above...
Will do  :y
« Reply #18 on: 18 July 2014, 16:08:16 »
Stupid question?
Ron.
If there is then you shouldn't use it foir exactly the same reasons why you shouldn't use it bin the cooling system ::)
As with most things, it is better, easier and cheaper to fix the problem than the symptoms :y
« Reply #19 on: 18 July 2014, 16:36:09 »
In which case you have a leak and when fixed it needs vaccing down for a period of time to boil the moisture off
scimmy_man
  • yorkshire
« Reply #20 on: 18 July 2014, 18:28:24 »
Stupid question?
Ron.
yup Halfords sell it, if you ask they will "fit" a bottle or two for you, if no impovement no charge.
« Reply #21 on: 18 July 2014, 18:32:09 »
Stupid question?
Ron.
No, no, no, and just no... :o
« Reply #22 on: 18 July 2014, 18:33:43 »
Just replaced valve on the 3.2, cost £3.50 from Vauxhall :)
snowy70838
« Reply #23 on: 18 July 2014, 20:08:27 »
I just topped the aircon up with one of those bottles from Halfords. I already have the connector with the gauge though so it cost me £34.
My aircon is now fine. But I was able to check mine first with the connector I have and I could see that there was gas, just not enough.
Thanks
« Reply #24 on: 18 July 2014, 20:25:33 »
Thanks
But how much. You can't tell. That's one reason why these refills are a waste of time.
If the refrigerant has leaked out over time, something else will have replaced it, and this needs to be removed before refilling with refrig. That's another reason why these refills are a waste of time.
TBH, the money spent on these is better spent on getting specialists to do it - unless you have the correct equipment, which isn't the refill adapters that Halfords sell.
« Reply #25 on: 18 July 2014, 20:43:52 »
£34!  just another £15 would have seen the job done properly!
serek
  • huntingdon
    • 3.2 mv6
« Reply #26 on: 18 July 2014, 22:03:29 »
I read a few feedback from people that that have used these recharge bottles and they have had very good results  :) Anyone used them for Omega's  :-\
if you need you air con services you can visit my place
I do offer for oof members £30  :y
snowy70838
« Reply #27 on: 18 July 2014, 23:49:15 »
Thanks
I can tell as the connector I have, which I never said I got from Halfords, has a pressure gauge. This told me that the system had gas in it and it was just below the required amount to make the system run.
If it had told me anything else then I would have either done nothing and lived without aircon or taken it to a specialist which I don't have time for.
Guess what, I put some gas in, not the whole bottle by any means, and now I have ice cold air conditioning.
Here was me thinking this was a friendly site....
« Reply #28 on: 18 July 2014, 23:51:36 »
Oh dear, someone who cannot take advice. Throws toys out of the pram  ::)  ;D ;D
« Reply #29 on: 19 July 2014, 00:02:38 »
Presure varies with temperature, which is why the system is charged by weight not volume, and why topups don't work...
Still, not my car ::)
Pages: 1 [2] 3 4  All   Go Up
Page created in 0.049 seconds with 16 queries.
