Author Topic: Return Springs  (Read 2745 times)
Andy663
  • Ayrshire
    • 3.0 MV6 (2000)
Return Springs
« on: 18 July 2014, 19:28:56 »
Hi, I'm needing two return springs for my rear brakes. The rear hub gets warm when driving due to one of the levers pressing against it, if the lever is manually pushed back and I don't use my handbrake will it be okay to drive until I can get the springs fitted?
thanks
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: Return Springs
« Reply #1 on: 24 July 2014, 21:44:03 »
Are you sure it's not a stiff handbrake cable?
flyer 0712
Re: Return Springs
« Reply #2 on: 28 July 2014, 10:53:39 »
I bought these for mine from flea bay...item number....131241957185...£8.02 including postage  :y
Andy663
  • Ayrshire
    • 3.0 MV6 (2000)
Re: Return Springs
« Reply #3 on: 28 July 2014, 15:47:17 »
Thanks, I got a set from my local stealer, £6.50.
terry paget
    • 3 Astras 2 Vectra
Re: Return Springs
« Reply #4 on: 28 July 2014, 17:43:52 »
I have never known them get weak. The right hand pull off spring is easy to remove, the left hand is difficult and I usually end up cutting it. Do others find this?
Re: Return Springs
« Reply #5 on: 28 July 2014, 20:23:37 »
I found the new one on nearside toughest get on , old ones ... one corroded in half and one missing . New ones all greased up  :y
